SIM7600 module does not connect to the network after I reconnect power supply
Hi everyone.
I have a LilyGO SIM7600, it works fine the first time, but it stops connecting to the network when I reconnect power supply. I use 5V with 2A.
  1. Connect power supply: The board turns on and connects to network. Everything ok.
  2. Disconnect power supply: The board turns off.
  3. Reconnect power supply: The board turns on but the SIM does not connect to the network.
The red led stays on constantly, and it does not blink. The AT commands tell me that SIM is in a "busy state".
AT+CMGS
+CME ERROR: SIM busy
AT+CGREG?
+CGREG: 0,0
Even if I restart the modem, it will still be in this state. It seems that the SIM is stuck in a previous state of the connection.
For the SIM can connect to the network again:
  1. I putting the SIM in a cell phone.
  2. I TURN OFF the cell phone.
  3. I Remove the SIM.
  4. Everything works again.
I tried with other SIMs, but the same thing happens. I use the Diagnostic code from TinyGSM.
#define TINY_GSM_MODEM_SIM7600
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// Set serial for AT commands (to the module)
// Use Hardware Serial on Mega, Leonardo, Micro
#ifndef __AVR_ATmega328P__
#define SerialAT Serial1
// or Software Serial on Uno, Nano
#else
#include <SoftwareSerial.h>
SoftwareSerial SerialAT(2, 3);  // RX, TX
#endif
// Increase RX buffer to capture the entire response
// Chips without internal buffering (A6/A7, ESP8266, M590)
// need enough space in the buffer for the entire response
// else data will be lost (and the http library will fail).
#ifndef TINY_GSM_RX_BUFFER
#define TINY_GSM_RX_BUFFER 1024
#endif
// See all AT commands, if wanted
// #define DUMP_AT_COMMANDS
// Define the serial console for debug prints, if needed
#define TINY_GSM_DEBUG SerialMon
// Range to attempt to autobaud
// NOTE:  DO NOT AUTOBAUD in production code.  Once you've established
// communication, set a fixed baud rate using modem.setBaud(#).
#define GSM_AUTOBAUD_MIN 9600
#define GSM_AUTOBAUD_MAX 115200
// Add a reception delay - may be needed for a fast processor at a slow baud
// rate #define TINY_GSM_YIELD() { delay(2); }
// Uncomment this if you want to use SSL
// #define USE_SSL
#define TINY_GSM_USE_GPRS true
#define TINY_GSM_USE_WIFI false
// set GSM PIN, if any
#define GSM_PIN ""
// Your GPRS credentials, if any
const char apn[]      = "wap.tmovil.cl";
const char gprsUser[] = "wap";
const char gprsPass[] = "wap";
// Your WiFi connection credentials, if applicable
const char wifiSSID[] = "YourSSID";
const char wifiPass[] = "YourWiFiPass";
// Server details
const char server[]   = "vsh.pp.ua";
const char resource[] = "/TinyGSM/logo.txt";
#include <TinyGsmClient.h>
// Just in case someone defined the wrong thing..
#if TINY_GSM_USE_GPRS && not defined TINY_GSM_MODEM_HAS_GPRS
#undef TINY_GSM_USE_GPRS
#undef TINY_GSM_USE_WIFI
#define TINY_GSM_USE_GPRS false
#define TINY_GSM_USE_WIFI true
#endif
#if TINY_GSM_USE_WIFI && not defined TINY_GSM_MODEM_HAS_WIFI
#endif
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SerialAT, SerialMon);
TinyGsm        modem(debugger);
#else
TinyGsm        modem(SerialAT);
#endif
#ifdef USE_SSL&& defined TINY_GSM_MODEM_HAS_SSL
TinyGsmClientSecure      client(modem);
const int                port = 443;
#else
TinyGsmClient  client(modem);
const int      port = 80;
#endif
  // Set console baud rate
  SerialMon.begin(115200);
  delay(10);
  //Turn on SIM7600
  pinMode(4, OUTPUT);
  digitalWrite(4, LOW);
  delay(100);
  digitalWrite(4, HIGH);
  delay(100);
  SerialAT.begin(115200, SERIAL_8N1, 26, 27);
  delay(6000);
  // Restart takes quite some time
  // To skip it, call init() instead of restart()
  SerialMon.print("Initializing modem...");
  //if (!modem.restart()) {
  if (!modem.init()) {
    SerialMon.println(F(" [fail]"));
    SerialMon.println(F("************************"));
    SerialMon.println(F(" Is your modem connected properly?"));
    SerialMon.println(F(" Is your serial speed (baud rate) correct?"));
    SerialMon.println(F(" Is your modem powered on?"));
    SerialMon.println(F(" Do you use a good, stable power source?"));
    SerialMon.println(F(" Try using File -> Examples -> TinyGSM -> tools -> AT_Debug to find correct configuration"));
    delay(10000);
    return;
  SerialMon.println(F(" [OK]"));
  String modemInfo = modem.getModemInfo();
  SerialMon.print("Modem Info: ");
  SerialMon.println(modemInfo);
  // Unlock your SIM card with a PIN if needed
  if (GSM_PIN && modem.getSimStatus() != 3) { modem.simUnlock(GSM_PIN); }
#endif
  // Wifi connection parameters must be set before waiting for the network
  SerialMon.print(F("Setting SSID/password..."));
  if (!modem.networkConnect(wifiSSID, wifiPass)) {
    SerialMon.println(" fail");
    delay(10000);
    return;
  SerialMon.println(" success");
#endif
#if TINY_GSM_USE_GPRS && defined TINY_GSM_MODEM_XBEE
  // The XBee must run the gprsConnect function BEFORE waiting for network!
  modem.gprsConnect(apn, gprsUser, gprsPass);
#endif
  SerialMon.print("Waiting for network...");
  if (!modem.waitForNetwork(
          600000L)) {  // You may need lengthen this in poor service areas
    SerialMon.println(F(" Is your sim card locked?"));
    SerialMon.println(F(" Do you have a good signal?"));
    SerialMon.println(F(" Is antenna attached?"));
    SerialMon.println(F(" Does the SIM card work with your phone?"));
    delay(10000);
    return;
  // GPRS connection parameters are usually set after network registration
  SerialMon.print("Connecting to ");
  SerialMon.print(apn);
  if (!modem.gprsConnect(apn, gprsUser, gprsPass)) {
    SerialMon.println(F(" Is GPRS enabled by network provider?"));
    SerialMon.println(F(" Try checking your card balance."));
    delay(10000);
    return;
#endif
  IPAddress local = modem.localIP();
  SerialMon.print("Local IP: ");
  SerialMon.println(local);
  SerialMon.print(F("Connecting to "));
  SerialMon.print(server);
  if (!client.connect(server, port)) {
    delay(10000);
    return;
  // Make a HTTP GET request:
  client.print(String("GET ") + resource + " HTTP/1.0\r\n");
  client.print(String("Host: ") + server + "\r\n");
  client.print("Connection: close\r\n\r\n");
  // Wait for data to arrive
  while (client.connected() && !client.available()) {
    delay(100);
    SerialMon.print('.');
  SerialMon.println();
  // Skip all headers
  client.find("\r\n\r\n");
  // Read data
  uint32_t timeout       = millis();
  uint32_t bytesReceived = 0;
  while (client.connected() && millis() - timeout < 10000L) {
    while (client.available()) {
      char c = client.read();
      // SerialMon.print(c);
      bytesReceived += 1;
      timeout = millis();
  client.stop();
  SerialMon.println(F("Server disconnected"));
  modem.networkDisconnect();
  SerialMon.println(F("WiFi disconnected"));
#endif
  modem.gprsDisconnect();
  SerialMon.println(F("GPRS disconnected"));
#endif
  SerialMon.print(F(" Received: "));
  SerialMon.print(bytesReceived);
  SerialMon.println(F(" bytes"));
  SerialMon.print(F(" Test:     "));
  SerialMon.println((bytesReceived == 121) ? "PASSED" : "FAILED");
  // Do nothing forevermore
  while (true) { delay(1000); }
You can try using this library ESP32 Save Data Permanently using Preferences Library | Random Nerd Tutorials and save the data
Thank you for reply.
I don't have data to store. The problem is that the SIM does not connect to the network unless I insert the SIM in the cell phone and turn off it.
What happens if you issue the following command before powering off?
AT+CPOF
It reset the board. The network still working after reset.
AT+CPOF
OK
RDY
+CPIN: READY
SMS DONE
PB DONE
If you now disconnect/reconnect the power is the SIM still busy?
Yes, it still busy, unfortunately. The SIM never loses network if I restart the modem, unless reconnect the power.
Not sure what you mean by that.
If you go into offline mode with
AT+CFUN=7
and you then power off the module completely... when you power on is the SIM available?
Yes, after SIM go into offline mode and i reconnect power supply, it still available. But it loses network connection when reconnect power for the third time.
I did the following:
  1. SIM connected to the network.
  2. I write AT+CFUN=7
  3. SIM go into offline mode.
  4. I disconnect/Reconnect the power.
  5. SIM still to network.
  6. Now, i Disconnect/Reconnect the power again.
  7. SIM loses network connection again.
