Ignore the Arduino, use the manual power-on button if there is one.
It should wake up and connect within about 20-30 seconds. If it’s the first power-on in a new location, it can take a little longer, but not forever.
The next step is to plug into the modem’s USB port, to watch the initialisation progress.
The following choices are -
Low supply current (needs up to 2A for a moment during cell negotiation)
Low signal, check your antenna.
Invalid or PIN locked SIM card
lastchancename: Thank you very much for response. Beyond pluggin in, can you please let me know what I need to do to see the initialization through the modem USB on my Macbook?
Thanks for suggestion, but I dont really understand. Are you talking about updating the Arduino library files? Not sure how to do that, but there is no serial monitor output from the UNO. The SIM7600 will not even connect to the 4G network.
