SIM800L and Arduino Sleep - getting whimsy Serial output after 5 calls
Hi everybody,
i'm working on project where i'm trying to achieve that arduino parse caller ID so i can use it later to send SMS with sensor reading data.
Somehow i made that code (with much googling) and it works great... But when i include arduino sleep part, it does work at beginning, but after i call SIM800 4-5 times with distinct of 30 seconds, i get unusable data on Serial, so i can't no longer parse correct number.
I tried many things, dropping baud rate to 1200, changing delay, but still i get strange characters after few calls.
Can anyone help me?
Thank you,
Matija
P.S. Serial Ouput in attachment, MCU is ATMEGA328P
#include <SoftwareSerial.h>
#include <avr/sleep.h>
SoftwareSerial SIM800(8, 7);
String buffer1;
unsigned int current_millis = 0;
String phone;
  buffer1.reserve(200);
  phone.reserve(20);
  Serial.begin(19200); //
  SIM800.begin(9600);
  SIM800.write("AT\r");  // because of SIM800L autobounding mode
  SIM800.write("AT+IPR=9600\r");  // set baud at 9600, i tried with 1200 and other, and with autobouding but still got same problem
  SIM800.write("AT+CMGF=1\r");  // set SMS mode to text
  SIM800.write("AT+CNMI=2,2,0,0,0\r");
  Serial.print(SIM800.readString());
  SIM800.write("AT+CLIP=1\r\n");
  SIM800.write("AT+SGPIO=0,7,1,0\r");
  SIM800.write("AT+CSCLK=2\r"); //power saving mode of SIM800L
  current_millis = millis();
  if (SIM800.available() > 0) {
    buffer1 = SIM800.readStringUntil('\n'); //Saving string then parsing caller number from it
    Serial.println(buffer1);
    parse();
  if ((millis() - current_millis) > 10000) { //Putting atmega tu sleep
    sleepNow();
    delay(1000);// tried many delays
void parse() {
  if (buffer1.indexOf("CLIP:") > 0) {
    phone = buffer1.substring(buffer1.indexOf("+CLIP: ") + 8, buffer1.indexOf("+CLIP: ") + 21); //parsing caller number
    Serial.println(phone);
    SIM800.write("ATH\r"); //hang out phone call
void sleepNow() { //PIN CHANGE INTERRUPT ON PIN 7,8 BECAUSE SOFTWARE SERIAL LIBRARY USE IT AND IT WILL WAKE UP ATMEGA
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);   // sleep mode is set herethe sleep bit in the mcucr register
  sleep_mode();            // here the device is actually put to sleep!!
  // THE PROGRAM CONTINUES FROM HERE AFTER WAKING UP
  sleep_disable();         // first thing after waking from sleep: disable sleep...
Hy, have you solved this problem?
