SIM800l and GY-NEO6MV2 GPS Module using Arduino Mega
Hello,
I am using a GSM module sim800l and GY-NEO6MV2 GPS Module with Arduino Mega. I want to use both of them at the same time. They are connected to Serial1 and Serial2. In the void loop(); if i use both of them serial1.available() and serial2.available(); none of them is working. I tested that if i use only the GSM module the code is working, it receives the call and then sends the location. Maybe i should put them to work for a certaint amount of time, i really dont know. Maybe you can help me.
#include <SoftwareSerial.h> //Software Serial header to communicate with GSM module
#include <TinyGPS++.h>
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
String Link = "The current Location is https://www.google.com/maps/place/"; //we will append the Lattitude and longitude value later int the program
String responce = "";
String Longitude = "";
String Latitude = "";
String Date ="";
String Time ="";
String result2 = "";
String SIM800_send(String incoming) //Function to communicate with SIM800 module
    Serial1.println(incoming); delay(100); //Print what is being sent to GSM module
    String result = "";
    while (Serial1.available()) //Wait for result
    char letter = Serial1.read();
    result = result + String(letter); //combine char to string to get result
return result; //return the result
  Serial2.begin(9600); //Serial COM for debugging
  Serial1.begin(9600);
  delay(1000); //wait for serial COM to get ready
  responce = SIM800_send("ATE1"); //Enable Echo if not enabled by default
  Serial.print ("Responce:"); Serial.println(responce);
  responce = SIM800_send("AT+CGATT=1"); //Set the SIM800 in GPRS mode
  responce = SIM800_send("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\" "); //Activate Bearer profile
  responce = SIM800_send("AT+SAPBR=3,1,\"APN\",\"net\""); //Set VPN options => 'RCMNET' 'www'
  delay(2000);
  responce = SIM800_send("AT+SAPBR=1,1"); //Open bearer Profile
  Serial.print ("Responce:"); Serial.println(responce); //Open bearer Profile
  delay(2000);
  responce = SIM800_send("AT+SAPBR=2,1"); //Get the IP address of the bearer profile
void prepare_message()
  //Sample Output for AT+CLBS=1,1
  int first_comma = responce.indexOf(','); //Find the position of 1st comma
  int second_comma = responce.indexOf(',', first_comma+1); //Find the position of 2nd comma
  int third_comma = responce.indexOf(',', second_comma+1); //Find the position of 3rd comma
  for(int i=first_comma+1; i<second_comma; i++) //Values form 1st comma to 2nd comma is Longitude
    Longitude = Longitude + responce.charAt(i);
  for(int i=second_comma+1; i<third_comma; i++) //Values form 2nd comma to 3rd comma is Latitude
    Latitude = Latitude + responce.charAt(i);
  Serial.println(Latitude); Serial.println(Longitude);
  Link = Link + Latitude + "," + Longitude; //Update the Link with latitude and Logitude values
  Serial.println(Link);
String incoming = "";
  while (Serial2.available() > 0)
    delay (1000);
    gps.encode(Serial2.read());
    if (gps.location.isUpdated())
      // Latitude in degrees (double)
      Serial.print("Latitude= ");
      Serial.print(gps.location.lat(), 6);
      Latitude = gps.location.lat();
      // Longitude in degrees (double)
      Serial.print(" Longitude= ");
      Serial.println(gps.location.lng(), 6);
      Longitude = gps.location.lng();
      // Raw date in DDMMYY format (u32)
      Serial.print("Raw date DDMMYY = ");
      Serial.println(gps.date.value());
      Date = gps.date.value();
      // Raw time in HHMMSSCC format (u32)
      Serial.print("Raw time in HHMMSSCC = ");
      Serial.println(gps.time.value());
      Time = gps.time.value();
      delay (5000);
  if (Serial1.available())
  { //Check if the SIM800 Module is telling anything
    char a = Serial1.read();
    Serial.write(a); //print what the module tells on serial monitor
    incoming = incoming + String(a);
    if (a == 13) //check for new line
    incoming =""; //clear the string if new line is detected
    incoming.trim(); //Remove /n or /r from the incomind data
    if (incoming=="RING") //If an incoming call is detected the SIM800 module will say "RING" check for it
     Serial.println ("Sending sms"); delay(1000);
     responce = SIM800_send("ATH"); //Hand up the incoming call using ATH
     delay (1000);
     responce = SIM800_send("ATE0"); //Disable Echo
     delay (1000);
     responce = "";
     if ( (Latitude=="") && (Longitude=="") )
      Serial1.println("AT+CLBS=1,1"); delay(5000); //Request for location data
       responce = responce + String(letter); //Store the location information in string responce
      Serial.print("Result Obtained as:");   Serial.print(responce); Serial.println("*******");
      prepare_message(); delay(1000); //use prepare_message funtion to prepare the link with the obtained LAT and LONG co-ordinates
     Serial1.println("AT+CMGF=1"); //Set the module in SMS mode
     Serial1.println("AT+CMGS=\"+40753159104\""); //Send SMS to this number
     Serial1.println(Link); // we have send the string in variable Link
     Serial1.println((char)26);// ASCII code of CTRL+Z - used to terminate the text message
  if (Serial.available())
    Serial1.write(Serial.read());
