Hi Everyone. So this is an IoT gas monitoring system. All works fine when the OLED code is commented out.
I am powering the SIM800L with an 18650 battery and the Oled through the Arduino Nano with my laptop.
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <SoftwareSerial.h>
SoftwareSerial gsmSerial(6, 7); // SoftwareSerial for GSM module
Adafruit_SSD1306 myDisplay(128, 64, &Wire); // OLED display
String writeApiKey = "api_key"; // ThingSpeak API Key
const int gasThreshold = 75;
gsmSerial.begin(9600);
delay(2000);
// myDisplay.begin(SSD1306_SWITCHCAPVCC, 0x3C);
// myDisplay.clearDisplay();
// myDisplay.setTextSize(2);
// myDisplay.setTextColor(SSD1306_WHITE);
// myDisplay.setCursor(0, 0);
// myDisplay.println(F("Gas Detector System"));
// myDisplay.display();
Serial.println(F("Initializing GSM..."));
delay(2000);
Serial.println(F("Warming up gas sensor..."));
delay(10000);
Serial.println(F("Gas sensor warmed up!"));
float sensorValue = analogRead(A0);
// updateDisplay(sensorValue);
Serial.print(F("Gas Value: "));
Serial.println(sensorValue);
if (sensorValue > gasThreshold) {
sendSMS("Gas detected! Take necessary action.");
Serial.println("Sending to ThingSpeak...");
sendToThingSpeak(sensorValue);
delay(5000); // Wait before checking again
delay(2000);
//void updateDisplay(float value) {
// myDisplay.print(F("Gas Value: "));
// myDisplay.print(value);
void sendToThingSpeak(float gasValue) {
Serial.println(F("Closing existing connections..."));
gsmSerial.println(F("AT+CIPSHUT"));
Serial.println(F("Setting single connection mode..."));
gsmSerial.println(F("AT+CIPMUX=0"));
Serial.println(F("Setting APN..."));
gsmSerial.println(F("AT+CSTT=\"internet.ng.airtel.com\""));
delay(2000);
Serial.println(F("Bringing up wireless connection..."));
gsmSerial.println(F("AT+CIICR"));
delay(2000);
Serial.println(F("Getting local IP address..."));
gsmSerial.println(F("AT+CIFSR"));
delay(2000);
Serial.println(F("Connecting to ThingSpeak..."));
gsmSerial.println(F("AT+CIPSTART=\"TCP\",\"api.thingspeak.com\",\"80\""));
delay(10000);
while (gsmSerial.available()) {
Serial.write(gsmSerial.read());
Serial.println(writeApiKey);
Serial.println(gasValue);
String url = "GET /update?api_key=" + writeApiKey +
"&field1=" + String(gasValue);
Serial.println(url);
Serial.print(F("Sending data: "));
delay(2000);
Serial.println("Sending data to ThingSpeak...");
gsmSerial.print(F("AT+CIPSEND="));
gsmSerial.println(url.length() + 2);
gsmSerial.print(url);
gsmSerial.write(0x0D);
gsmSerial.write(0x0A);
delay(8000);
Serial.println(F("Closing the connection..."));
void sendSMS(String message) {
Serial.println(F("Sending SMS..."));
gsmSerial.println(F("AT+CMGF=1")); // Set the GSM Module to text mode
delay(2000);
gsmSerial.println(F("AT+CMGS=\"+phone_number\""));
delay(100);
gsmSerial.println(message);
delay(100);
gsmSerial.write(26); // ASCII code of CTRL+Z
delay(100);
gsmSerial.println();
delay(5000);
Serial.println(F("SMS sent."));
This is an example of my serial monitor:
Gas Value: 71.00
Gas Value: 75.00
Gas Value: 73.00
Gas Value: 89.00
Sending SMS...
SMS sent.
Setting APN...
api_key
89.00
GET /update?api_key=api_key&field1=89.00
Sending data: GET /update?api_key=api_key&field1=89.00
Gas Value: 54.00
Gas Value: 54.00
Gas Value: 54.00
Gas Value: 54.00
Gas Value: 53.00
my build report is
Sketch uses 17206 bytes (56%) of program storage space. Maximum is 30720 bytes.
Global variables use 752 bytes (36%) of dynamic memory, leaving 1296 bytes for local variables. Maximum is 2048 bytes.
