Hi there!
I'm trying to make an app that uploads data from sdcard to my ftp server using a teensy 3.6 and SIM800L GPRS modem on Serial2. The initialisation goes without errors; It seems my modem doesn't answer "OK" after AT+FTPPUT=2,48 command. Because of this, the sendATcommand throws a timeout.
AT+FTPPUT=1
OK
+FTPPUT: 1,1,xxxx
then:
AT+FTPPUT=2,48
...... and I don't get any answer from SIM800... so here might be my problem.
Here's my code:
#include <SD.h>
#define SD_FAT_TYPE 3
const int chipSelect = BUILTIN_SDCARD;
bool debug = 1;
bool roaming = false;
char* file_name = "testA.txt";
File dataFile;
File dataFileCopy;
String apn_name = "live.vodafone.com";
String apn_username = "live";
String apn_password = "";
String ftp = "myftpserver.my";
String ftp_user = "user";
String ftp_password = "mypassword";
byte answer = 0;
if (debug) {Serial.begin(9600);}
Serial2.begin(9600);
Serial.println("Initializing SD card...");
if (!SD.begin(chipSelect)) {
Serial.println("SD initialization failed!");
//GPRS part
answer = powerUp_Sim900();
if (answer == 0) { Serial.println("powerUp_Sim900 failure");}
else if (answer == 1) {delay(20000); answer = initSim900();} //Delay to let startuo the SIM900 Module
if (debug) {Serial.println("--- Answer initSim900: " + String(answer));}
if (answer == 0) {/*Send SMS that Sim900 init failed*/}
else if (answer == 1) {answer = initSim900FTP();}
if (debug) {Serial.println("--- Answer initSim900FTP: " + String(answer));}
if (answer == 0) {/*Send SMS that Sim900FTP init failed*/}
else if (answer == 1) {answer = Sim900FTPSend();}
if (debug) {Serial.println("--- Answer Sim900FTPSend: " + String(answer));}
if (answer == 0) {/*Send SMS that Sim900FTPSend failed*/}
byte initSim900() {
byte answer = 0;
int i = 0;
while (i < 10 && answer == 0){
answer = sendATcommand("AT+CREG?","+CREG: 0,1", 1000);
i++;
if (roaming and answer == 0) {
while (i < 20 && answer == 0){
answer = sendATcommand("AT+CREG?","+CREG: 0,5", 1000);
i++;
if (answer == 1){answer = sendATcommand("AT+SAPBR=3,1,\"Contype\",\"GPRS\"","OK", 1000);}
String com = "AT+SAPBR=3,1,\"APN\",\"" + apn_name + "\"";
if (answer == 1){answer = sendATcommand(string2char(com), "OK", 1000);}
if (answer == 1){
answer = 0;
i = 0;
while (i < 3 && answer == 0){
answer = sendATcommand("AT+SAPBR=1,1", "OK", 10000);
if (answer == 0){sendATcommand("AT+SAPBR=0,1", "OK", 10000);}
i++;
if (answer == 1){answer = sendATcommand("AT+SAPBR=2,1", "OK", 1000);}
return answer;
byte initSim900FTP() {
byte answer = 0;
answer = sendATcommand("AT+FTPCID=1", "OK", 1000);
String com = "AT+FTPSERV=\"" + ftp + "\"";
if (answer == 1){answer = sendATcommand("AT+FTPPORT=21", "OK", 1000);}
com = "AT+FTPUN=\"" + ftp_user + "\"";
com = "AT+FTPPW=\"" + ftp_password + "\"";
com = "AT+FTPPUTNAME=\"" + String(file_name) + "\"";
if (answer == 1){answer = sendATcommand("AT+FTPPUTPATH=\"/G/\"", "OK", 1000);}
return answer;
byte Sim900FTPSend (){
byte answer = 0;
Serial.println("Try AT+FTPPUT:");
if (answer = sendATcommand("AT+FTPPUT=1", "+FTPPUT:1,1,", 60000) == 1) {
int data_size = 0;
Serial.println("--- AT+FTPPUT=1 OK");
while(Serial2.available()==0);
char aux = Serial2.read();
do{
data_size *= 10;
data_size += (aux-0x30);
} while(aux != 0x0D);
data_size=48;
//Serial.print("--- data_size"); Serial.println(data_size);
dataFile = SD.open(file_name);
Serial.println("SD.open file");
String XcomA = "";
String XcomB = "";
XcomA.concat("AT+FTPPUT=2,");
XcomA.concat(data_size);
//XcomA.concat("""");
XcomA.concat("\r");
XcomB.concat("+FTPPUT:2,");
XcomB.concat(data_size);
XcomB.concat("\"");
//XcomB.concat("""");
char XxcomA[XcomA.length()];
char XxcomB[XcomB.length()];
XcomA.toCharArray(XxcomA,XcomA.length());
XcomB.toCharArray(XxcomB,XcomB.length());
if (dataFile) {
int archivosize = dataFile.size();
Serial.print("dataFile OK, size:"); Serial.println(archivosize);
while(dataFile.available() and answer == 1){
while(archivosize >= data_size){
if (answer = sendATcommand(XxcomA,XxcomB,60000) == 1) {
Serial.println("Write file pieces");
for(int d = 0; d < data_size; d++){
Serial2.write(dataFile.read());
Serial.write(dataFile.read());
archivosize -= 1;
else {answer = 0; Serial.println("--ERR sendATcommand(XxcomA,XxcomB,30000)");}
String ScomA = "";
String ScomB = "";
ScomA.concat("AT+FTPPUT=2,");
ScomA.concat(archivosize);
ScomA.concat("\"");
ScomB.concat("+FTPPUT:2,");
ScomB.concat(archivosize);
ScomB.concat("\"");
char CcomA[ScomA.length()];
char CcomB[ScomB.length()];
ScomA.toCharArray(CcomA,ScomA.length());
ScomB.toCharArray(CcomB,ScomB.length());
if (sendATcommand(CcomA,CcomB,30000) == 1) {
for(int t = 0; t < archivosize; t++){
// close the file:
dataFile.close();
if (sendATcommand("AT+FTPPUT=2,0", "+FTPPUT:1,0", 30000)==1){
if (debug) {Serial.println("File " + String(file_name) + " uploaded..." );}
else {answer = 0; Serial.println("--- AT+FTPPUT=1 ERROR");}
return answer;
unsigned char sendATcommand(char* ATcommand, char* expected_answer1, unsigned int timeout) {
unsigned char x = 0;
unsigned char answer = 0;
char response[100];
unsigned long previous;
memset(response, '\0', 100);
delay(100);
while( Serial2.available() > 0) Serial2.read();
Serial.println(ATcommand);
Serial2.println(ATcommand);
x = 0;
previous = millis();
do{
if(Serial2.available() != 0){
response[x] = Serial2.read();
x++;
if (strstr(response, expected_answer1) != NULL) {
answer = 1;
if (strstr(response, "OK") != NULL) {
answer = 1;
} while((answer == 0) && ((millis() - previous) < timeout));
if (debug) {if((millis() - previous) < timeout) Serial.println(response); else Serial.println("sendATcommand - timeout");}
return answer;
unsigned char sendATcommandWData(char* ATcommand, char* expected_answer1, char* buffer_data unsigned int timeout) {
char response[100];
delay(100);
x = 0;
do{
x++;
answer = 1;
answer = 1;
return answer;
byte powerUp_Sim900() {
byte answer = 0;
int i = 0;
powerSim900();
while (i < 2 && answer == 0){
answer = sendATcommand("AT+CREG?","+CREG:", 1000);
i++;
if (answer == 0) {powerSim900();}
i = 0;
i++;
return answer; //send 1 if power up
byte powerDown_Sim900() {
byte answer = 0;
int i = 0;
powerSim900();
i++;
if (answer == 1) {powerSim900();}
i = 0;
while (i < 2 && answer == 1){
i++;
return answer; //send 0 if power up
void powerSim900() {
pinMode(Sim900PowerPin, OUTPUT);
digitalWrite(Sim900PowerPin,LOW);
digitalWrite(Sim900PowerPin,HIGH);
delay(2000);
delay(5000);
char* string2char(String command){
if(command.length() != 0){
char *p = const_cast<char*>(command.c_str());
return p;
byte checkFile() {
byte answer = 0;
if(SD.exists(file_name)) {answer = 1;}
return answer;
