SIM800l GSM.reset() problem
Hi, I'm building an SMS Alarm for the refrigerator in my biochemistry lab.
I'm using a SIM800L, the one that can be supplied directly with 5V.
I'm facing some issue with the SIM800L library I'm using.
The GSM.reset() function is not working properly, the Arduino gets stuck waiting for a response message from the GSM module.
This is the reset() code from the library:
void Sim800L::reset()
    if (LED_FLAG) digitalWrite(LED_PIN,1);
    digitalWrite(RESET_PIN,1);
    digitalWrite(RESET_PIN,0);
    // wait for the module response
    this->SoftwareSerial::print(F("AT\r\n"));
    while (_readSerial().indexOf("OK")==-1 )
    //wait for sms ready
    while (_readSerial().indexOf("SMS")==-1 );
    if (LED_FLAG) digitalWrite(LED_PIN,0);
I did some experimenting with direct AT communication with the module. I noticed that the module it's not always responding "SMS ready" to the first "AT" message, even though it's registered to the network and it's capable to send SMS.
So I tried to remove the second to last line of the code from the library but Arduino still gets stuck waiting for a response from the module. To make it work properly I had to remove also the part of the code in which Arduino waits for the OK message.
Why I'm facing this communication problem and what can I do to fix it?
Solved: The problem was about the software serial communication and the auto baud rate of the module.
I fixed the Module Baud Rate at 9600 and this solved all my problems.
AT+IPR=9600 //set the baud rate at the desired value
AT&W //Save the current setting
Now, every time it boots up I can read
RDY
+CFUN: 1
+CPIN: READY
Call Ready
SMS Ready
