SIM800L issue
Hello,
I also have a problem with my sim800l…
I use a diode 1N4007 after the VCC5V and it gives me something like 4V.
Below, you will see the dialog with the module using the FONAtest library. Things look look good at the beginning except when it writes “<— ERROR” and " ??? ".
At the end when I write a phone number nothing happends…
Do you have an idea ?
Thanks
François
FONA basic test
Initializing…(May take 3 seconds)
Attempting to open comm with ATs
—> AT
—> AT
—> AT
—> AT
—> AT
<— AT
—> AT
<— AT
—> ATE0
<— ATE0
—> ATE0
<— OK
—> AT+CVHU=0
<— OK
—> ATI
<— SIM800 R14.18
OK
+CPIN: READY
—> AT+CPMS=“SM”,“SM”,“SM”
<— ERROR
FONA is Ok
Found ? ? ?
—> AT+GSN
<— 865674037529308
Module IMEI: 865674037529308
[ ?] Print this menu
[ a] read the ADC 2.8V max (FONA800 & 808)
[ b] read the Battery V and % charged
[ C] read the SIM CCID
[ U] Unlock SIM with PIN code
[ S] create Serial passthru tunnel
FONA>
Call Ready
SMS Ready
s
Send to #
I have same issue. have u got any solution for the same? If so,can u please share with us? Thanks in advance
SIM800l worked with Arduino UNO and the code below for sending SMS under PIN HIGH condition, but important points:
  1. Power suply: Arduino UNO is limmiting the current and provides not enough power, therefore you need different power source for SIM800 or do like I did: plugged extrenal power supply DC 5V/2000ma into Arduino and briged the + into SIM800
  2. Need the library from GitHub - cristiansteib/Sim800l: Library sim800l for Arduino UNO (maybe sim900l work) Pay attention of TX and RX pins. You can modify defaults in library in …/Arduino/libraries/Sim800l-master/Sim800l.h
  3. Code
#include <Sim800l.h>
#include <SoftwareSerial.h> //is necesary for the library!!
Sim800l Sim800l; //to declare the library
char text[161]=“Text for SMS1”; //buffer to store message
char text1[161]=“Text for SMS1”; //buffer to store message
char number[12]=“your mobile # to send SMS to”; //phone number to send message
//int cnt;
bool error; //to catch the response of sendSms
// constants won’t change. They’re used here to set pin numbers:
const int buttonPin1 = 10; // comment1 the number of the pushbutton pin
const int buttonPin2 = 12; // comment2 number of the pushbutton pin
//const int ledPin = 13; // the number of the LED pin
// variables will change:
int buttonPin1State = 0; // variable for reading the pushbutton status
int buttonPin2State = 0; // variable for reading the pushbutton status
void setup(){
// initialize the pushbutton pin as an input:
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
Sim800l.begin(); // initializate the library.
Serial.begin(9600); // initialize serial communications
void loop(){
// read the state of the pushbutton value:
buttonPin1State = digitalRead(buttonPin1);
buttonPin2State = digitalRead(buttonPin2);
//Send the message and display the status
if (buttonPin1State == HIGH) {
error = Sim800l.sendSms(number,text);
if (buttonPin2State == HIGH) {
error = Sim800l.sendSms(number,text1);
//I hope this helps
25Samy:
Hello,
Thanks
François
You need a RX pin voltage divider (max 2.8v)
jirgale: I have same issue. have u got any solution for the same? If so,can u please share with us? Thanks in advance
Hi, Goto this link there is one circuit suggested which working good.
Also try that library, because it gives 100% feedback of every task we ask to GSM.
Thank you
