Hi fellows,
I'm working on a project that powered by Atmega328p and SIM800L. While the alarm triggered, the device will upload data to Firebase Realtime database using POST method, then send SMS to a certain phone. It's OK to only send SMS and only send data to Firebase. But, if I try the software of device to do them together when alarm triggered, it fails to send an SMS and produce data to send to Firebase database. There is some parts of my code:
void updateSerial()
while (Serial.available())
gsm.write(Serial.read());//Forward what Serial received to Software Serial Port
while(gsm.available())
Serial.write(gsm.read());//Forward what Software Serial received to Serial Port
void sendSMS(String tel){
//for(int i = 0; i < 4; i++){
//Serial.println(tels[i]);
gsm.println("AT+CMGS=\"+"+tel+"\"");//change ZZ with country code and xxxxxxxxxxx with phone number to sms
updateSerial();
gsm.print("Alarm Alert!"); //text content
updateSerial();
gsm.write(26);
updateSerial();
//delay(2000);
/*for(int j=0; j<5; ++j){
digitalWrite(buzzer, HIGH);
delay(1500);
digitalWrite(buzzer, LOW);
void triggerAlarm(){
isTriggered = 1;
alarmInitTime = millis();
sendSMS(primary_tel);
//MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
//Send data to Firebase part:
String response;
do{
gsm.println("AT+CCLK?"); // Send command to get current time
delay(500); // Wait for the response to be available
gsm.readStringUntil('\"');// Read response from SIM800L
response = gsm.readStringUntil('\r');
//response = gsm.readStringUntil('\"');
if(response.length() > 1)
response.remove(response.length() - 1);
Serial.println(response);
updateSerial();
}while(response.length() != 20);
do{
data = "";
data += "{\"action\": ";
data += "\"3\", ";
data += "\"time\": \"";
data += response;
data += "\"";
data += "}";
}while(data.length() != 47);
Serial.println(data.length());
post_to_firebase();
void post_to_firebase()
Serial.println(data);
//Start HTTP connection
gsm.println("AT+HTTPINIT");
updateSerial();
//Enabling SSL 1.0
if(USE_SSL == true){
gsm.println("AT+HTTPSSL=1");
updateSerial();
//Setting up parameters for HTTP session
gsm.println("AT+HTTPPARA=\"CID\",1");
updateSerial();
//Set the HTTP URL - Firebase URL and FIREBASE SECRET
Serial.println(db_url);
gsm.println(db_url);
updateSerial();
//Setting up re direct
gsm.println("AT+HTTPPARA=\"REDIR\",1");
updateSerial();
//Setting up content type
gsm.println("AT+HTTPPARA=\"CONTENT\",\"application/json\"");
updateSerial();
//Setting up Data Size
//+HTTPACTION: 1,601,0 - error occurs if data length is not correct
gsm.println("AT+HTTPDATA=" + String(data.length()) + ",50000");
updateSerial();
//waitResponse("DOWNLOAD");
//delay(DELAY_MS);
//Sending Data
gsm.println(data);
updateSerial();
//Sending HTTP POST request
gsm.println("AT+HTTPACTION=1");
updateSerial();
/*for (uint32_t start = millis(); millis() - start < 20000;){
while(!gsm.available());
String response = gsm.readString();
if(response.indexOf("+HTTPACTION:") > 0)
delay(DELAY_MS);
//+HTTPACTION: 1,603,0 (POST to Firebase failed)
//+HTTPACTION: 0,200,0 (POST to Firebase successfull)
//Read the response
gsm.println("AT+HTTPREAD");
//waitResponse("OK");
//delay(DELAY_MS);
updateSerial();
//Stop HTTP connection
gsm.println("AT+HTTPTERM");
//waitResponse("OK",1000);
//delay(DELAY_MS);
updateSerial();
//Connect to the internet
void gprs_connect()
//DISABLE GPRS
gsm.println("AT+SAPBR=0,1");
waitResponse("OK",60000);
delay(DELAY_MS);
//Connecting to GPRS: GPRS - bearer profile 1
gsm.println("AT+SAPBR=3,1,\"Contype\",\"GPRS\"");
updateSerial();
//sets the APN settings for your sim card network provider.
gsm.println("AT+SAPBR=3,1,\"APN\",\""+APN+"\"");
updateSerial();
//sets the user name settings for your sim card network provider.
if(USER != ""){
gsm.println("AT+SAPBR=3,1,\"USER\",\""+USER+"\"");
updateSerial();
//sets the password settings for your sim card network provider.
if(PASS != ""){
gsm.println("AT+SAPBR=3,1,\"PASS\",\""+PASS+"\"");
updateSerial();
//after executing the following command. the LED light of
//gsml blinks very fast (twice a second)
//enable the GPRS: enable bearer 1
gsm.println("AT+SAPBR=1,1");
//waitResponse("OK", 30000);
updateSerial();
delay(DELAY_MS);
//Get IP Address - Query the GPRS bearer context status
gsm.println("AT+SAPBR=2,1");
updateSerial();
delay(DELAY_MS);
* Function: gprs_disconnect()
* AT+CGATT = 1 modem is attached to GPRS to a network.
* AT+CGATT = 0 modem is not attached to GPRS to a network
boolean gprs_disconnect()
//Disconnect GPRS
gsm.println("AT+CGATT=0");
//delay(DELAY_MS);
//DISABLE GPRS
//gsm.println("AT+SAPBR=0,1");
//waitResponse("OK",60000);
//delay(DELAY_MS);
return true;
* checks if the gprs connected.
boolean is_gprs_connected()
gsm.println("AT+CGATT?");
if(waitResponse("+CGATT: 1",6000) == 1) { return false; }
return true;
//Handling AT COMMANDS
boolean waitResponse(String expected_answer="OK", unsigned int timeout=2000) //uncomment if syntax error (arduino)
//boolean waitResponse(String expected_answer, unsigned int timeout) //uncomment if syntax error (esp8266)
uint8_t x=0, answer=0;
String response;
unsigned long previous;
//Clean the input buffer
while( gsm.available() > 0) gsm.read();
//NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN
previous = millis();
do{
//if data in UART INPUT BUFFER, reads it
if(gsm.available() != 0){
char c = gsm.read();
response.concat(c);
x++;
//checks if the (response == expected_answer)
if(response.indexOf(expected_answer) > 0){
answer = 1;
}while((answer == 0) && ((millis() - previous) < timeout));
return answer;
void init_gsm()
//Testing AT Command
gsm.println("AT");
updateSerial();
//Checks if the SIM is ready
gsm.println("AT+CPIN?");
waitResponse("+CPIN: READY");
delay(DELAY_MS);
//Turning ON full functionality
gsm.println("AT+CFUN=1");
updateSerial();
//Turn ON verbose error codes
gsm.println("AT+CMEE=2");
updateSerial();
//Enable battery checks
gsm.println("AT+CBATCHK=1");
updateSerial();
//Register Network (+CREG: 0,1 or +CREG: 0,5 for valid network)
//+CREG: 0,1 or +CREG: 0,5 for valid network connection
gsm.println("AT+CREG?");
waitResponse("+CREG: 0,");
delay(DELAY_MS);
//setting SMS text mode
gsm.print("AT+CMGF=1\r");
waitResponse("OK");
delay(DELAY_MS);
In this part, triggerAlarm() function:
isTriggered = 1;
String response;
do{
updateSerial();
do{
data = "";
data += "\"3\", ";
data += response;
data += "\"";
data += "}";
post_to_firebase();
if I disable one of the these function calls: post_to_firebase() (posts data to firebase) or sendSMS() (sends SMS) by commenting out, the other called function work. But, if I call both functions in my code, it fails sending SMS and it could not produce the data with length of 47 characters and it stuck on this loop:
do{
data = "";
data += "\"3\", ";
data += response;
data += "\"";
data += "}";
When I don't use loop and just the produce data whatever I can like this:
data = "";
data += "\"3\", ";
data += response;
data += "\"";
data += "}";
it sends data to Firebase with no values, just with "error: no data supplied", or name.
I also tried clean the buffer of the SoftwareSerial variable "gsm" between calling of two functions like:
while(gsm.available)
gsm.read();
but nothing changed. I am really stuck now.
