Hello everyone! I'm doing a project which uses the module SIM800L. but I'm having problems with its power supply. When the module arrived at my home, I tested it using a LM338 regulated to provide 4V to the module. However, the module wasn't registrating the SIM Card, and I thought it could be a problem from the power suppy. However, after I tried to change the power supply nothing more is working.
Currently, using a lot of different power supplier, when I measure then without the SIM800L the voltimeter indicates that there's a voltage of 4V ~ 4,5V. However, when I put the module at this supply, the voltimeter measures a voltage of only 1,5V, and the regulator heats. So, my doubt is if my problem is more probable to be a problem at the power supply, or if it's more probable to be a problem from the module.
