SIM800L return garbage response
if I am sending AT command using Software Serial library GSM SIM800 give garbage value in response .if I send AT directly
from Serial monitor it works properly.I post code below
#include <SoftwareSerial.h>
SoftwareSerial myGsm(7,8);//rx,tx
void setup(){
  myGsm.begin(115200);
  Serial.print("power up" );
void loop(){
Serial.println("Hello");
  myGsm.println("AT");
  printSerialdata();
   myGsm.println("AT+CPIN?");
  printSerialdata();
  myGsm.println("AT+CREG?");
  printSerialdata();
  myGsm.println("AT+CGATT?");
  printSerialdata();
  myGsm.println("AT+CIPSHUT");
  printSerialdata();
  myGsm.println("AT+CIPSTATUS");
  printSerialdata();
  myGsm.println("AT+CIPMUX=0");
  printSerialdata();
  myGsm.println("AT+CSTT=\"airtelgprs.com\",\"\",\"\"");
  printSerialdata();
  myGsm.println("AT+CIICR");
  printSerialdata();
  myGsm.println("AT+CIFSR");
  printSerialdata();
  myGsm.println("AT+CIPSTART=\"TCP\",\"iot1.os3.co.in\",\"8088\"");
   delay(2000);
  printSerialdata();
  myGsm.println("AT+CIPSEND");
  printSerialdata();
  myGsm.println("POST /apt/test HTTP/1.0");
  myGsm.println("#026");
  printSerialdata();
  printSerialdata();
void printSerialdata()
 while(myGsm.available()!=0)
 Serial.write(myGsm.read());
Kindly Check you baudrate at your serial monitor at the lower right. then choose the baudrate thats matches up with your program's baudrate.
