Sim800L send multiple data failed
I am using sim800l with arduino nano, with the library named “SIm800L Library revised” available on internet with the example “sendSMS” example given
#include <Sim800L.h>
#include <SoftwareSerial.h>
#define RX  10
#define TX  11
Sim800L GSM(RX, TX);
 * In alternative:
 * Sim800L GSM;                       // Use default pinout
 * Sim800L GSM(RX, TX, RESET);
 * Sim800L GSM(RX, TX, RESET, LED);
char* text;
char* number;
bool error; 					//to catch the response of sendSms
void setup(){
	GSM.begin(4800);
	text="Testing Sms";  		//text for the message.
	number="2926451386"; 		//change to a valid number.
	error=GSM.sendSms(number,text);
	// OR
	//Sim800L.sendSms("+540111111111","the text go here")
void loop(){
	//do nothing
this code works fine with the text. but now i want to send multiple data in single sms
i am using GPS module with TinyGPS++ library for lat and long. this gives me data in following format
gps.location.lat();
gps.location.lng();
when i convert these into strings with
dtostrf(gps.location.lat(),2,4,latString);
dtostrf(gps.location.lng(),2,6,lonString);
and then sending sms
GSM.sendSms(number,latString);
example of this GPS is given
#include <TinyGPS++.h>
   This sample demonstrates TinyGPS++'s capacity for extracting custom
   fields from any NMEA sentence.  TinyGPS++ has built-in facilities for
   extracting latitude, longitude, altitude, etc., from the $GPGGA and
   $GPRMC sentences.  But with the TinyGPSCustom type, you can extract
   other NMEA fields, even from non-standard NMEA sentences.
   It requires the use of SoftwareSerial, and assumes that you have a
   4800-baud serial GPS device hooked up on pins 4(RX) and 3(TX).
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 4800;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
   By declaring TinyGPSCustom objects like this, we announce that we
   are interested in the 15th, 16th, and 17th fields in the $GPGSA
   sentence, respectively the PDOP (F("positional dilution of precision")),
   HDOP (F("horizontal...")), and VDOP (F("vertical...")).
   (Counting starts with the field immediately following the sentence name,
   i.e. $GPGSA.  For more information on NMEA sentences, consult your
   GPS module's documentation and/or http://aprs.gids.nl/nmea/.)
   If your GPS module doesn't support the $GPGSA sentence, then you
   won't get any output from this program.
TinyGPSCustom pdop(gps, "GPGSA", 15); // $GPGSA sentence, 15th element
TinyGPSCustom hdop(gps, "GPGSA", 16); // $GPGSA sentence, 16th element
TinyGPSCustom vdop(gps, "GPGSA", 17); // $GPGSA sentence, 17th element
  ss.begin(GPSBaud);
  Serial.println(F("UsingCustomFields.ino"));
  Serial.println(F("Demonstrating how to extract any NMEA field using TinyGPSCustom"));
  Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
  Serial.println(F("by Mikal Hart"));
  // Every time anything is updated, print everything.
  if (gps.altitude.isUpdated() || gps.satellites.isUpdated() ||
    pdop.isUpdated() || hdop.isUpdated() || vdop.isUpdated())
    Serial.print(F("ALT="));   Serial.print(gps.altitude.meters());
    Serial.print(F(" PDOP=")); Serial.print(pdop.value());
    Serial.print(F(" HDOP=")); Serial.print(hdop.value());
    Serial.print(F(" VDOP=")); Serial.print(vdop.value());
    Serial.print(F(" SATS=")); Serial.println(gps.satellites.value());
  while (ss.available() > 0)
    gps.encode(ss.read());
individually its working fine but now i want to merge these data’s, the format i want to send is
"Lat="0000\n
"Long="0000\n
in single sms
i have tried many methods but with no luck. anyone can help me to Solve this problem
trm33:
I am using sim800l with arduino nano, with the library named "SIm800L Library revised" available on internet with the example "sendSMS" example given
Please provide a link to the library.
trm33:
gps.location.lat();
gps.location.lng();
This is not a format but rather two function calls.
trm33:
individually its working fine but now i want to merge these data's, the format i want to send is
"Lat="0000\n
"Long="0000\n
in single sms
What methods have you tried? What was the reason for them not to work?
    // initialize gms
    // initialize gps
    // is gps reading available?
        // update internal variables
        // format sms text
        // send sms
    // is serial available?
        // do serial stuff
LightuC:
    // initialize gms
    // initialize gps
        // format sms text
        // send sms
        // do serial stuff
Library is available in library manager of arduino IDE with the name "SIm800l library revised"
these functions are converted into string they individually work fine
gps.location.lat();
gps.location.lng();
if i use latSTring and LonString individually works fine
i have tried the following method to merg
String multi="LAT=";
multi +=latString;
multi +="Longi=";
multi +=lonString;
multi+=String(\r\n);
if there is data type mistake then plz correct it or if u have another merging technique then plz send
trm33:
multi +=latString;
multi +="Longi=";
multi +=lonString;
Please also use code-tags for short snippets.
What exactly is not working with that example? Apart from the obvious error (missing "" in last line) this will work. However, I would strongly recommend against using big-s String class.
You can use this method:
   Purpose:     This function converts the latitude and longitude arguments to a formated
                sms text. The format is given by 'Lat=-00.0000\nLong=-000.0000\n'.
   Arguments:   'smsBuffer' a pointer to a char array with a minimum size of 29 bytes
                'latitude' the latitude to put into the sms text
                'longitude' the longitude to put into the sms text
   Assumptions: 'latitude' is assumed to be in range of [-90, 90]
                'longitude' is assumed to be in range of [-180, 180]
   Notes:       No leading zeros are added and for positive numbers no plus sign is added.
                The content 'smsBuffer' can therefore vary from 'Lat=0.0000\nLong=0.0000\n'
                to 'Lat=-00.0000\nLong=-000.0000\n'. There will always be four decimal
                places.
void prepareSMSText(char* smsBuffer, double latitude, double longitude)
  char* insertionPtr = smsBuffer;
  // Put first text into buffer
  strncpy(insertionPtr, "Lat=", 4);
  insertionPtr += 4;
  // Convert latitude and store it in buffer
  dtostrf(latitude, 6, 4, insertionPtr);
  uint8_t textLength = strlen(smsBuffer);
  insertionPtr = &smsBuffer[textLength];
  // Insert second text into buffer
  strncpy(insertionPtr, "\nLong=", 6);
  insertionPtr += 6;
  // Convert longitude and store it in buffer
  dtostrf(longitude, 6, 4, insertionPtr);
  // Add last '\n' and terminate string
  *insertionPtr++ = '\n';
  *insertionPtr = '\0';
