sim800L ...
Hi guys
I have problem with the sim800l module l,it won’t connect to network.
-module has a separate 3.7 lipo battery (common gnd to Arduino)
-signal I get 20
-at+cpin ready
Cops 1
Creg 0,2
Did the manual input to 1 but unit flashes 1 per sec, looking for Network, have enough power on it (3,7 840 mAh) also tested with a 12v battery with a step down
Cheers
Danny1000:
won't connect to network.
Possibly better worded as "won't connect to 2G network". Is your network 2G?
Can you read the RSSI and Net Status to the serial monitor?
-jim lee
What at commands are they?
The sim can work in 2g, others have managed to make it work with the same provider.
Thanks for the help
At+csq 20,0
At+creg?
0,2
At+creg=1
At+creg?
1,0
The module won't connect to network
Has 3.7 lipo battery with common gnd
The led is flashing fast
I have soldered also a bigger capacitor to it, stock is 100uf should be 300 it's now 1000.
What can I do to connect it to network?
Thanks
Is the SIM card properly inserted?
Hi
Yes,I have bought another module from unv that comes better than the Chinese,now it blinks 3 times, ring stays on and after 15/20 sec it resets
You need a supply with 2A surge current. This reference recommends a 1200mAh li-po battery.
https://lastminuteengineers.com/sim800l-gsm-module-arduino-tutorial/
aarg:
sim was unlocked before?
