Sim900 AT+CCID ERROR
I have my SIM900 connected to a 12v 2A power source, I have inserted my sim card changed it to 3G/2G(autoconnect) ( I did research it to know wheteher it is possible and it turns out it is, the only problem would be not having the same speed according to them) There are no pin/password on the sim. There is still a remaining balance (should be enough to send a text or two)
Also my SIM900 netlight led still blinks every 1 second.
I also did try AT commands that I found on the internet and this is the results:
I have also posted this on this site: arduino uno - SIM900 AT+CCID ERROR - Arduino Stack Exchange
CODE:
#include <SoftwareSerial.h>
//Create software serial object to communicate with SIM900
SoftwareSerial mySerial(7, 8); //SIM900 Tx & Rx is connected to Arduino #7 & #8
  //Begin serial communication with Arduino and Arduino IDE (Serial Monitor)
  Serial.begin(19200);
  //Begin serial communication with Arduino and SIM900
  mySerial.begin(19200);
  Serial.println("Initializing...");
  mySerial.println("AT"); //Handshaking with SIM900
  updateSerial();
  mySerial.println("AT+CSQ"); //Signal quality test, value range is 0-31 , 31 is the best
  updateSerial();
  mySerial.println("AT+COPS");
  updateSerial();
  mySerial.println("AT+CCID"); //Read SIM information to confirm whether the SIM is plugged
  updateSerial();
  mySerial.println("AT+CREG?"); //Check whether it has registered in the network
  updateSerial();
  updateSerial();
void updateSerial()
  while (Serial.available())
    mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
  while(mySerial.available())
    Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
SERIAL MONITOR:
Initializing...
AT
OK
AT+CSQ
+CSQ: 17,0
OK
AT+COPS?
+COPS: 0
OK
AT+CCID?
ERROR
AT+CREG?
+CREG: 1,0
OK
I think the command you want is without the question mark...
AT+CCID
Seemed to work OK on my SIM7600.
A T + C C I D CRCRLF+ C C I D :   8 9 6 4 0 1 2 0 1 1 1 0 9 0 9 9 1 5 2 CRLFCRLFO K CRLF
41542B434349440D0D0A2B434349443A20383936343031323031313130393039393135320D0A0D0A4F4B0D0A
Hi, I tried removing the "?" and it is still an error. Plus my netlight led is still blinking every 1 sec.
What about this command
AT+CICCID
All these command do is get the ID from the SIM. Is the SIM inserted correctly?
Still error.
