I have a sensor which is uploading information to a server using a sim900 from
using this library GSM-GPRS-GPS-Shield/doc at GSMSHIELD · MarcoMartines/GSM-GPRS-GPS-Shield · GitHub
I'm having problems though because after a number of hours it seems to stop sending to the server, I know that the uno is still running and the sensor is being used but the GSM shield is unable to upload the information.
Any ideas why this might be and is there a way to reset the sim900 in the code or to detect if it has crashed?
Thanks
Hardware might be having problems.
Software might be having problems.
No.
Of course. Send it an AT command. Read the response. If there is no response in a reasonable time, use it to send you a text message.
Most probably you have lost command sync with the 900
By which I mean you must wait for reply from 900 and never send another AT command before the previous command responce has been see.
I have tested many of the GSM modules most initially fail to respond in this situation but eventually some firmware timeout resets and the module comes back, my notes on the 900 imply this as with the Seimans tc 35i the only way out of this situation is to physically reset the module.
- Happy Coding..
I've just had a quick look at the schematics and it looks like you can use software to turn the shield on and off. If this is the case then periodically send an AT to the shield and if it doesn't respond within a certain time turn the shield off and back on again.
