SIM900 didnt respond incoming SMS command
Hello, I have a program to make a communication between phone and arduino uno. I tried to make and send input command using serial monitor. It works, the LED is on, and it sent me an SMS like I set to do.
      #include <SoftwareSerial.h>
      #define CH1 2
      #define CH2 3
      #define CH3 4
      #define CH4 5
      SoftwareSerial mySerial(7, 8);
       mySerial.begin(9600);   // Setting the baud rate of GSM Module
       SendMessageSiap();
       delay(5000);
       pinMode(CH1, OUTPUT);
       pinMode(CH2, OUTPUT);
       pinMode(CH3, OUTPUT);
       pinMode(CH4, OUTPUT);
       digitalWrite(CH1,HIGH);
       digitalWrite(CH2,HIGH);
       digitalWrite(CH3,HIGH);
       digitalWrite(CH4,HIGH);  // Setting the baud rate of Serial Monitor   (Arduino)
       delay(100);
       if (Serial.available()>0)
       switch(Serial.read())
       case 'A':
         onPin1();
       SendMessageA();
       case 'B':
         onPin2();
      SendMessageB();
       case'C':
         onPin3();
         SendMessageC();
       case 'D':
         onPin4();
     SendMessageD();
     case 'a':
     offPin1();
     SendMessagea();
     case 'b':
     offPin2();
     SendMessageb();
     case 'c':
     offPin3();
     SendMessagec();
     case 'd':
     offPin4();
     SendMessaged();
     case 'f':
     allOff();
      SendMessagef();
     case 'n':
     allOn();
     SendMessageN();
     if (mySerial.available()>0)
     Serial.write(mySerial.read());
       void SendMessageA()
       mySerial.println("AT+CMGF=1");    //Sets the GSM Module in Text Mode
       delay(1000);  // Delay of 1000 milli seconds or 1 second
       mySerial.println("AT+CMGS=\"+6285726576677\"\r"); // Replace x with mobile number
       mySerial.println("Lampu 1 Nyala");// The SMS text you want to send
       delay(100);
       mySerial.println((char)26);// ASCII code of CTRL+Z
      void SendMessageSiap()
      mySerial.println("Sistem Siap");// The SMS text you want to send
      delay(100);
    void SendMessageB()
      mySerial.println("Lampu 2 Nyala");// The SMS text you want to send
      delay(100);
      void SendMessageC()
       mySerial.println("Lampu 3 Nyala");// The SMS text you want to send
      delay(100);
    void  RecieveMessage()
    mySerial.println("AT+CNMI=2,2,0,0,0"); // AT Command to receive a live SMS
    void allOn(){
    digitalWrite(CH1, LOW);
    digitalWrite(CH2, LOW);
    digitalWrite(CH3, LOW);
    digitalWrite(CH4, LOW);
Now, I got issues to make the command is present from phone, how to change the serial monitor to phone as input command?
I tried this method :
    #include <SIM900.h>
    #include <sms.h>
    SMSGSM sms;
    boolean started=false;
    char smsbuffer[160];
    char n[20];
    int relay1=2;
    int relay2=3;
    int relay3=4;
    int relay4=5;
    void setup(){
    pinMode(relay1,OUTPUT);
    pinMode(relay2,OUTPUT);
    pinMode(relay3,OUTPUT);
    pinMode(relay4,OUTPUT);
    if(gsm.begin(9600)){
    started=true;
    if(started){
    delsms();
    sms.SendSMS("+6285726576677","4 Saklar SMS Menyala");
    void loop(){
    started=true;
    int pos=0;
    if(started){
    pos=sms.IsSMSPresent(SMS_ALL);
    if(pos){
    sms.GetSMS(pos,n,smsbuffer,100);
    if(!strcmp(smsbuffer,"relay1on")){
      digitalWrite(relay1,HIGH);
      sms.SendSMS(n,"Relay 1 Telah Aktif");
    if(!strcmp(smsbuffer,"relay2on")){
      digitalWrite(relay2,HIGH);
      sms.SendSMS(n,"Relay 2 Telah Aktif");
    if(!strcmp(smsbuffer,"relay3on")){
      digitalWrite(relay3,HIGH);
      sms.SendSMS(n,"Relay 3 Telah Aktif");
    if(!strcmp(smsbuffer,"relay4on")){
      digitalWrite(relay4,HIGH);
      sms.SendSMS(n,"Relay 4 Telah Aktif");
    if(!strcmp(smsbuffer,"relay1off")){
      digitalWrite(relay1,LOW);
      sms.SendSMS(n,"Relay 1 Telah di Nonaktifkan");
    if(!strcmp(smsbuffer,"relay2off")){
      digitalWrite(relay2,LOW);
      sms.SendSMS(n,"Relay 2 Telah di Nonaktifkan");
    if(!strcmp(smsbuffer,"relay3off")){
      digitalWrite(relay3,LOW);
      sms.SendSMS(n,"Relay 3 Telah di Nonaktifkan");
    if(!strcmp(smsbuffer,"relay4off")){
      digitalWrite(relay4,LOW);
      sms.SendSMS(n,"Relay 4 Telah di Nonaktifkan");
    if(!strcmp(smsbuffer,"semuaon")){
      sms.SendSMS(n,"Semua Relay Telah Aktif");
    if(!strcmp(smsbuffer,"semuaoff")){
      sms.SendSMS(n,"Semua Relay Telah di Nonaktifkan");
    delsms();
    delay(100);
    void delsms()
    for (int i=0; i<10; i++)
      int pos=sms.IsSMSPresent(SMS_ALL);
      if (pos!=0)
        if (sms.DeleteSMS(pos)==1){}else{}
No error, but the arduino didnt respond my sms command.
I need help to convert the getSMS command to the first sketch or fix the 2nd sketch. Thankyou for your help!
