SIM900 function
Hi.
Based on the function found here http://www.cooking-hacks.com/documentation/tutorials/arduino-gprs-gsm-quadband-sim900
int8_t sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout){
    uint8_t x=0,  answer=0;
    char response[100];
    unsigned long previous;
    memset(response, '\0', 100);    // Initialice the string
    delay(100);
    while( Serial.available() > 0) Serial.read();    // Clean the input buffer
    Serial.println(ATcommand);    // Send the AT command
        x = 0;
    previous = millis();
    // this loop waits for the answer
    do{
        // if there are data in the UART input buffer, reads it and checks for the asnwer
        if(Serial.available() != 0){
            response[x] = Serial.read();
            x++;
            // check if the desired answer is in the response of the module
            if (strstr(response, expected_answer) != NULL)
                answer = 1;
        // Waits for the asnwer with time out
    }while((answer == 0) && ((millis() - previous) < timeout));
    return answer;
which
1 .Sends AT commands to SIM900 module
2. Reading the answer
3. Comparing them to the expected answer
4. Return 1 or 0 depending if the answer was correct or wrong.
I would like to modify this function in order to receive the actual responce also .
Something like
return ( 1 or 0 , responce)
or whatever is posible in order to use that responce later in my code.
Can be done ?
Could you please guide me on how to do it ?
Thank you in advance
The following code seems that is working ..
String sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout){
  char response[100];
  String reply = "";
  memset(response, '\0', 100);    // Initialize the string
  delay(100);
  while( SIM900.available() > 0) SIM900.read();    // Clean the input buffer
  SIM900.println(ATcommand);    // Send the AT command
 // Serial.println(ATcommand);
  x = 0;
  do{
    if(SIM900.available() != 0){
      response[x] = SIM900.read();
      x++;
      //Serial.println(response);
        answer = 1;
  reply +=answer ;
  reply += " , ";
  reply += response;
   return reply;
  //reply = (answer + "#" + response);
Please verify that there is NO ERROR in the above function
