[SIM900] I can receive only one SMS
Hi everyone, currently I build a security system for my home using a GSM shield with SIM900.
My objective is to control my system with SMS.
I made various searches on the use of SIM900 and I succed to send SMS but my problem is for receiving SMS. In fact I can received the first SMS properly but when I send an other SMS to the shield I read only the first SMS. And it doesn’t matter the number of SMS I send to the SIM900 I only read the first SMS.
I have tried to delete all messages after each SMS but the problem is still the same…
My program is :
int x;
int8_t answer;
int onModulePin= 9;
char aux_string[30];
char SMS[200];
String test = "";
int count=0;
String nop = "NO";
String mdp = "PASSWORD";
 pinMode(onModulePin, OUTPUT);
  power_on();
  delay(3000);
  sendATcommand(aux_string, "OK", 2000);
    delay(3000);
  while( (sendATcommand("AT+CREG?", "+CREG: 0,1", 500) ||
            sendATcommand("AT+CREG?", "+CREG: 0,5", 500)) == 0 );  //Tant que l'on n'est pas connecté au réseau
  sendATcommand("AT+CNMI=1,1,", "+CMTI:\"SM\",2", 1000);
  sendATcommand("AT+CMGF=1", "OK", 1000);//Mode SMS texte
  sendATcommand("AT+CMGDA=\"DEL ALL\"", "OK", 6000); //Supprime tous les messages de la carte
  sendATcommand("AT+CPMS=\"SM\",\"SM\",\"SM\"", "OK", 1000); //Selectionne la mémoire
  send_SMS("DEMARRAGE");
  test = read_SMS();
 if(test.equals(mdp)){
  Serial.println("CODE BON");
  send_SMS("ALARME ACTIVEE");
if(test.equals(nop)){ }
 else{
  Serial.println("WRONG PASSWORD");
  read_SMS() = "";
void power_on(){
    uint8_t answer=0;
    // checks if the module is started
    answer = sendATcommand("AT", "OK", 2000);
    if (answer == 0)
        // power on pulse
        digitalWrite(onModulePin,HIGH);
        delay(3000);
        digitalWrite(onModulePin,LOW);
        // waits for an answer from the module
        while(answer == 0){     // Send AT every two seconds and wait for the answer
String read_SMS(){
  answer = sendATcommand("AT+CMGR=1,0", "+CMGR:", 200);    // reads the first SMS
    if (answer == 1)
        answer = 0;
        while(Serial.available() == 0);
        // this loop reads the data of the SMS
        do{
            // if there are data in the UART input buffer, reads it and checks for the asnwer
            if(Serial.available() > 0){
                SMS[x] = Serial.read();
                x++;
                // check if the desired answer (OK) is in the response of the module
                if (strstr(SMS, "OK") != NULL)
                    answer = 1;
        }while(answer == 0);    // Waits for the asnwer with time out
        SMS[x] = '\0';
        Serial.println(SMS);
        return(nop);
int8_t send_SMS(char* sms_text){
  sprintf(aux_string,"AT+CMGS=\"%s\"", "+33XXXXXXXXX");
    answer = sendATcommand(aux_string, ">", 2000);    // send the SMS number
    if (answer == 1)
        Serial.println(sms_text);
        Serial.write(0x1A);
        answer = sendATcommand("", "OK", 20000);
        if (answer == 1)
            Serial.print("Sent ");
            Serial.print("error ");
        Serial.println(answer, DEC);
int8_t sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout){
    uint8_t x=0,  answer=0;
    char response[100];
    unsigned long previous;
    memset(response, '\0', 100);    // Initialice the string
    delay(100);
    while( Serial.available() > 0) Serial.read();    // Clean the input buffer
    Serial.println(ATcommand);    // Send the AT command
    x = 0;
    previous = millis();
    // this loop waits for the answer
    do{
        if(Serial.available() != 0){
            response[x] = Serial.read();
            x++;
            // check if the desired answer is in the response of the module
            if (strstr(response, expected_answer) != NULL)
                answer = 1;
    }while((answer == 0) && ((millis() - previous) < timeout));
    return answer;
And when I send a first SMS an an other after I obtain that :
Sent AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
“REC UNREAD”,"+33XXXXXXXXX","",“17/02/19,17:32:54+04” // The first SMS which I sent, everything goes well
I send a first SMS
OK
WRONG PASSWORD
AT+CMGDA=“DEL ALL”
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
AT+CMGR=1,0
“REC UNREAD”,"+33XXXXXXXXX","",“17/02/19,17:32:54+04” // I have sent an other SMS with a different text…
I send a first SMS
OK
So if someone have an idea…
See you soon !!
