SIM900 post
Hi, how post in a link like http://google.lt with SIM900 with AT command? i use this libarys: http://www.gsmlib.org/download.html
I don’t understand the question.
i need send data to link, like this:
numdata = inet.httpPOST(“www.test.com”, 80, “/arduino/new.php”, “testas=asd”, msg, 50);
but i cant use this because when i send data to new.php i start TCP server
works fine but not working gsm.SimpleWrite(“aaa”); and i cant read this with php socket_read($socket,10000); but if i dont use
numdata = inet.httpPOST(“www.test.com”, 80, “/arduino/new.php”, “testas=asd”, msg, 50); works fine, but i need send data to web…
my code:
arduino
#include "SIM900.h"
#include "SoftwareSerial.h"
#include "inetGSM.h";
float tempC = 0, dregn = 0;
int numdata, led = 13, state, flag = 0;
InetGSM inet, inets;
char msg[50];
const float SUPPLY_VOLTAGE = 5.0;
boolean started=false;
void setup(){
  pinMode(led, OUTPUT);
  Serial.println("GSM Shield ArduiCar");
  if (gsm.begin(9600)){
    Serial.println("Software Serial begin at 9600");
    gsm.forceON();
    started=true;
  if(started){
      numdata = inet.httpPOST("www.klondaikas.lt", 80, "/arduino/newIp.php", "testas=asd", msg, 50);
       delay(5000);
      inet.attachGPRS("internet.tele2.lt", "", "");
      gsm.WhileSimpleRead();
  if(started){
      Serial.println("APN Settings ok! Starting GPRS Connection!");
      gsm.SimpleWriteln("AT+CIFSR");
      delay(5000);
      inet.connectTCPServer(5000);
      delay(5000);
  state = gsm.read();
  if (state == 'o'){
    digitalWrite(led, HIGH);
    gsm.SimpleWrite("aaa");
  }else if (state == 'f'){
    digitalWrite(led, LOW);
    gsm.SimpleWrite("bbb");
  }else if(state == 'g'){
    Serial.println(temp());
    gsm.SimpleWrite(temp());
float temp(){
  const int sensor_voltage = analogRead(5);
  const float voltage = sensor_voltage * SUPPLY_VOLTAGE / 1024;
  return (voltage * 100);
float dreg(){
  dregn = analogRead(4);
  //dregn = dregn / 1023 * 100;
  return dregn;
and php when i send and read TPC
<?php
$service_port = '5000';
$address = '77.219.69.39';
$socket = socket_create(AF_INET, SOCK_STREAM, SOL_TCP);
$result = socket_connect($socket, $address, $service_port);
$json = array("dregme" => 0, "temperatura" => 0);
socket_write($socket, 'o');
$json["dregme"] = socket_read($socket,10000);
//echo socket_read($socket,100);
//socket_close($socket);
echo json_encode($json);
