I've got a SIM 900 shield (http://www.lankatronics.com/modules-and-sensors/gsm-gprs/sim900-gsm-gprs-shield-development-board.html) and I have stacked it on to a Arduino UNO board. The jumpers on the SIM900 shield is for softwareserial communication. I have used the code that is mentioned in the link, but when I open up the serial monitor nothin is shown. I tried sening AT commands using SScom, but nothing happens.
From the little I know i assumeit is not communicating using pin 7,8.
Please post the program that you are using.
Is SoftwareSerial actually using pins 7 and 8 ?
Do you need to do anything, set a jumper maybe, to tell the board to use SoftwareSerial instead of hardware serial ?
The documentation says it is using 7, 8. Jumpers are set to use softwareserial.
Here's the program:
//Serial Relay - Arduino will patch a
//serial link between the computer and the GPRS Shield
//at 19200 bps 8-N-1
//Computer is connected to Hardware UART
//GPRS Shield is connected to the Software UART
#include <SoftwareSerial.h>
SoftwareSerial GPRS(7, 8);
unsigned char buffer[64]; // buffer array for data recieve over serial port
int count=0; // counter for buffer array
GPRS.begin(19200); // the GPRS baud rate
Serial.begin(19200); // the Serial port of Arduino baud rate.
if (GPRS.available()) // if date is comming from softwareserial port ==> data is comming from gprs shield
while(GPRS.available()) // reading data into char array
buffer[count++]=GPRS.read(); // writing data into array
if(count == 64)break;
Serial.write(buffer,count); // if no data transmission ends, write buffer to hardware serial port
clearBufferArray(); // call clearBufferArray function to clear the storaged data from the array
count = 0; // set counter of while loop to zero
if (Serial.available()) // if data is available on hardwareserial port ==> data is comming from PC or notebook
GPRS.write(Serial.read()); // write it to the GPRS shield
void clearBufferArray() // function to clear buffer array
for (int i=0; i<count;i++)
{ buffer[i]=NULL;} // clear all index of array with command NULL
It seems like the communication is not taking place between the arduino board and the SIM900 shield. Any ideas why this might be and any suggestions to resolve this?
