Hi, this is my first project with Arduino and also the first attempt at connecting to the Cloud.
I have no experience with the troubles I am encountering and I would really appreciate your help.
I have an Arduino Mega 2560 and a SIM900 and I am trying to connect to a server at cloudmqtt.com
So far from the responses from the Serial Monitor it should be working properly, but sadly it is not sending the message to the server.
I insert the responses from the AT commands in the Serial Monitor down below, and also the Code I am running.
Do you guys see any mistake in the code?
In the LOG url I get this:
2019-02-05 10:09:21: New client connected from 88.0.235.55 as cloudmqtt-ws-ui-0.42801106527850075 (c1, k60, u'sefbkjmy').
2019-02-05 10:09:31: New connection from 2.141.129.160 on port 11529.
2019-02-05 10:09:44: Invalid protocol version 3 in CONNECT from 2.141.129.160.
2019-02-05 10:09:44: Socket error on client , disconnecting.
#include <SoftwareSerial.h>
SoftwareSerial SIM900(10,11);
void setup () {
SIM900.begin(19200);
Serial.begin(19200);
Serial.println("Setup");
delay(5000);
void loop () {
Send_data_cloud ();
delay(3000);
void Send_data_cloud (){
Serial.println("");
Serial.println("Communication SIM900/Arduino");
SIM900.println("AT");
printSerialData();
Serial.println("");
SIM900.println("AT+CGATT=1"); //
printSerialData();
Serial.println("");
SIM900.println("AT+CMEE=2");
delay(2000);
printSerialData();
Serial.println("Connecting to APN");
SIM900.println("AT+CSTT=\"movistar.es\",\"\",\"\""); //Retornarà 'AT+CSTT='movistar.es','','','OK'
delay(5000);
printSerialData();
Serial.println("GPRS connection");
SIM900.println("AT+CIICR"); //la resposta esperada és “OK”
delay(5000);
printSerialData();
delay(2000);
Serial.println("Local IP");
SIM900.println("AT+CIFSR");
delay(5000);
printSerialData();
Serial.println("Connecting to Port and Server");
SIM900.println("AT+CIPSTART=\"TCP\",\"m13.cloudmqtt.com\",\"11529\"");
delay(5000);
printSerialData();
delay(3000);
Serial.println("Enviant CONNECT i PUBLISH al servidor...");
SIM900.println("AT+CIPSEND");
delay(5000);
printSerialData();
send_connect();
send_publish();
delay(5000);
printSerialData();
Serial.println("Shutting down...");
SIM900.println("AT+CIPSHUT");
delay(5000);
printSerialData();
delay(2000);
void send_connect(){
int i;
char con[50] = {0x10,0x2A,0x00,0x04,0x4D,0x51,0x54,0x54,0x03,0xC2,0x00,0x3C,0x00,0x06,0x43,0x4C,0x49,0x45,0x4E,0x54,0x00,0x08,0x73,0x65,0x66,0x62,0x6B,0x6A,0x6D,0x79,0x00,0x0C,0x53,0x47,0x72,0x76,0x4D,0x49,0x43,0x66,0x55,0x63,0x6C,0x4F};
//CONN RL PLEN M Q T T LVL FL KA CIDLEN C L I E N T
//10 2A 0004 4D515454 03 C2 003C 0006 434C49454E54
//ULEN s e f b k j m y PWLEN S G r v M I C f U c l O
//0008 736566626B6A6D79 000C 534772764D49436655636C4F
for (i=0;i<44;i++){
SIM900.write(con[i]);
void send_publish(){
int i;
char pub[50] = {0x30,0x15,0x00,0x0A,0x6A,0x6F,0x73,0x65,0x70,0x74,0x6F,0x70,0x69,0x63,0x68,0x6F,0x6C,0x61,0x6A,0x6F,0x73,0x65,0x70};
//PUB RL TPLEN j o s e p t o p i c h o l a j o s e p
//30 15 000A 6A6F736570746F706963 686F6C616A6F736570
for (i=0;i<23;i++){
SIM900.write(pub[i]);
SIM900.print("}");
SIM900.write(0x1A);
void printSerialData(){ //Response from AT commands
while (SIM900.available()!=0){
Serial.write(SIM900.read());
