SIM900 webserver problem
Hello everyone ,
I need your help in the below ...
Now I connected SIM900 with Arduino Uno, Iam trying to use SIM900 as a web server to control relay and everything working okay
here is my code
Author      : Rafek Gorgay
Version     : Final v1.0
Description : This is the final version v1.0.
We use Web Server through GSM Shield to be able to control the Arduino remotely.
We control 1 Relay.
# include <SoftwareSerial.h>
#define led0 A0
#define led1 A1
#define led2 A2
#define led3 A3
SoftwareSerial GSM(7, 8); // Configure Serial Pins Rx,Tx
unsigned int timer_counter;  //timer counter
int IP_obtained_led = 13;  //IP_obtained_led on pin 13
String check_IP_status;  //to save the IP from SIM900
String check_connection_status; //to check connection status
char gsm_read;  //to get the one byte from SIM900
int count = 0;    //counter
String data;  //to read data from remote IP
String check_webServer_status;  //to check status of webServer
void ShowSerialData()        // To get feedback from GSM module
	while (GSM.available() != 0)
		Serial.write(char(GSM.read()));
void GSM_setup()       // GSM configuration setup
	check_IP_status.equals("");  //reset check_IP_status
	count = 0;  // reset count
	GSM.println("AT+CSQ"); // Signal quality check
	delay(100);
	ShowSerialData();
	GSM.println("AT+CGATT?"); // Check if GPRS attached or not
	delay(100);
	ShowSerialData();
	GSM.println("AT+CIPSHUT"); // Reset the IP session
	delay(100);
	ShowSerialData();
	GSM.println("AT+CIPSTATUS"); // Check if the IP stack is initialized
	delay(100);
	ShowSerialData();
	GSM.println("AT+CIPMUX=0"); // To keep things simple, I’m setting up a single connection mode
	delay(100);
	ShowSerialData();
	GSM.println("AT+CSTT= \"estatico.claro.com.co\""); // SIM APN Configuration
	delay(100);
	ShowSerialData();
	GSM.println("AT+CIICR"); // Now bring up the wireless. Please note, the response to this might take some time
	delay(10000);
	ShowSerialData();
	GSM.println("AT+CIFSR"); // Get Local IP
	delay(100);
		// to save the IP in check_IP_status
		gsm_read = GSM.peek();
		if (count < 26)
			check_IP_status += gsm_read;
		count++;
void webServer_setup()  //WebServer Configuration
	check_webServer_status = "";  //reset check_webServer_status
	count = 0;  //reset counter
	GSM.println("AT+CIPSERVER=1,80"); // configure SIM900 as web server
	delay(100);
	ShowSerialData();
	GSM.println("AT+CIPSTATUS"); // check web server status
	delay(100);
		// to save the status of webServer in check_webServer_status
		if (count < 45)
			check_webServer_status += gsm_read;
		count++;
void timer_int()  //Timer Configuration
	// initialize timer1
	noInterrupts(); // disable all interrupts
	TCCR1A = 0;
	TCCR1B = 0;
	TCNT1 = 0;
	TCCR1B |= (1 << CS12) | (1 << CS10);  // Set CS10 and CS12 bits for 1024 prescaler
	TIMSK1 |= (1 << TOIE1);   // enable timer overflow interrupt
	interrupts(); // enable all interrupts
void connection_status()  // to check connection status if it was down re start configuration
	check_connection_status = ""; //reset check_connection_status
	timer_counter = 0;  //reset timer_counter
	delay(100);
		if (count < 23)
			check_connection_status += gsm_read;
	if (!(check_connection_status.startsWith("AT+CGATT?\r\n+CGATT: 1\r\n0"))) // check if the GPRS is up or not (if not enter the if condition to re configure)
		check_IP_status = ""; //reset check_IP_status
		digitalWrite(IP_obtained_led, LOW); // set the IP led off
		while (!(check_IP_status.endsWith("190.127.131.65"))) // to check if the SIM obtain IP or not(the program will not start till the SIM get the IP:190.127.131.65)
			GSM_setup();
		digitalWrite(IP_obtained_led, HIGH);  // set the IP led on
		while (!(check_webServer_status.endsWith("LISTENING"))) // to check if the webservice working or not
			webServer_setup();
	pinMode(IP_obtained_led, OUTPUT);     // set IP_obtained_led as output
	pinMode(led0, OUTPUT);
	pinMode(led1, OUTPUT);
	pinMode(led2, OUTPUT);
	pinMode(led3, OUTPUT);
	digitalWrite(led0, LOW);
	digitalWrite(led1, LOW);
	digitalWrite(led2, LOW);
	digitalWrite(led3, LOW);
	delay(100);
	GSM.begin(115200);
	delay(15000);
	Serial.print("Starting ......");
		GSM_setup();
		webServer_setup();
	timer_int();  // start timer
	data = "";
	// to get data from system
		data += (char(GSM.peek()));
	// check the data from Remote IP and take actions
	if (data.startsWith("on1"))
	if (data.startsWith("off1"))
		digitalWrite(led0, HIGH);
	/*if (data.startsWith("on2"))
	if (data.startsWith("off2"))
	digitalWrite(led1, HIGH);
	if (data.startsWith("on3"))
	if (data.startsWith("off3"))
	digitalWrite(led2, HIGH);
	if (data.startsWith("on4"))
	if (data.startsWith("off4"))
	digitalWrite(led3, HIGH);
	// every about 11 min check the connection status
	if (timer_counter > 150)
		connection_status();
ISR(TIMER1_OVF_vect)  // timer counter
	timer_counter++;
I bought static IP so there is not problem in NAT
My problem is the device working fine for 4 hours then i cant connect the web server, I triend to ping the IP it reply.
