Simon Says Problem
Hello, we have a problem with the understanding of this programm for a Simon Says game.
Especially the function of current and previousMillis.
Thank you
Eva
//Returns the position of Button pressed (0, 1, 2, or 3) or -1 if no button is pressed in the time period.
int waitForButton(int delay)
int buttonPressed = -1;
int input; // Taster gedrückt
boolean buttonBackUp = false;
currentMillis = millis(); // The number of ms since the program started running
previousMillis = currentMillis; // Records the point when we start spinning the loop.
// Keep spinning the loop until “delay” seconds have passed.
while (currentMillis - previousMillis < delay & tasterWiederOben == false)
// Read the button and record when it has been pushed down.
for (int pin = 0; pin < 4 & tasterWiederOben == false; pin++)
if (digitalRead(taster[pin]) == HIGH)
buttonPressed = pin;
// Show the LED pushed.
digitalWrite(leds[pin], HIGH);
// It is possible the button is still being pushed.
// This loop spins until the button is let up.
input = digitalRead(taster[pin]);
if (input == LOW)
buttonBackUp = true;
// Turn the LED pushed off.
digitalWrite(leds[pin], LOW);
// See if they took to long.
if (currentMillis - previousMillis > delay)
buttonPressed = -1; // They took to long to let the button up so they lose.
return buttonPressed;
You didn’t say what the problem is.
Please remember to use code tags when posting code
Posting your complete sketch is a good idea too
Did you mean to use & (bitwise and) in the lines like this or did you perhaps mean to use && (logical and) ?
