Simon Says with the MPR121 Cap Sense Board
Update Made some progress and need a bit of help with the loop (), details in my last post below.
Hello all, I'm looking for help taking the following Simon Says code and making it work with the MPR121 Cap Sense Library instead of regular push buttons. I've got my circuit up and running with an Arduino Nano, and I've already tested the MPR121 using the example sketch provided by the library. I'm newish to programming and I just don't quite understand how the Simon Says code works and how the Cap Sense library could easily be used for input.
For reference:
Link to the Simon Says Tutorial
Link to the MPR121 Library I'm using.
Simon-Says Code that I currently have running:
 SparkFun Inventor's Kit
 Example sketch 16
 Spark Fun Electronics
 Oct. 7, 2014
 Simon Says is a memory game. Start the game by pressing one of the four buttons. When a button lights up,
 press the button, repeating the sequence. The sequence will get longer and longer. The game is won after
 13 rounds.
 Generates random sequence, plays music, and displays button lights.
 Simon tones from Wikipedia
 - A (red, upper left) - 440Hz - 2.272ms - 1.136ms pulse
 - a (green, upper right, an octave higher than A) - 880Hz - 1.136ms,
 0.568ms pulse
 - D (blue, lower left, a perfect fourth higher than the upper left)
 587.33Hz - 1.702ms - 0.851ms pulse
 - G (yellow, lower right, a perfect fourth higher than the lower left) -
 784Hz - 1.276ms - 0.638ms pulse
 Simon Says game originally written in C for the PIC16F88.
 Ported for the ATmega168, then ATmega328, then Arduino 1.0.
 Fixes and cleanup by Joshua Neal <joshua[at]trochotron.com>
 This sketch was written by SparkFun Electronics,
 with lots of help from the Arduino community.
 This code is completely free for any use.
 Visit http://www.arduino.cc to learn about the Arduino.
* Public Constants
#define NOTE_B0 31
#define NOTE_C1 33
#define NOTE_CS1 35
#define NOTE_D1 37
#define NOTE_DS1 39
#define NOTE_E1 41
#define NOTE_F1 44
#define NOTE_FS1 46
#define NOTE_G1 49
#define NOTE_GS1 52
#define NOTE_A1 55
#define NOTE_AS1 58
#define NOTE_B1 62
#define NOTE_C2 65
#define NOTE_CS2 69
#define NOTE_D2 73
#define NOTE_DS2 78
#define NOTE_E2 82
#define NOTE_F2 87
#define NOTE_FS2 93
#define NOTE_G2 98
#define NOTE_GS2 104
#define NOTE_A2 110
#define NOTE_AS2 117
#define NOTE_B2 123
#define NOTE_C3 131
#define NOTE_CS3 139
#define NOTE_D3 147
#define NOTE_DS3 156
#define NOTE_E3 165
#define NOTE_F3 175
#define NOTE_FS3 185
#define NOTE_G3 196
#define NOTE_GS3 208
#define NOTE_A3 220
#define NOTE_AS3 233
#define NOTE_B3 247
#define NOTE_C4 262
#define NOTE_CS4 277
#define NOTE_D4 294
#define NOTE_DS4 311
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_FS4 370
#define NOTE_G4 392
#define NOTE_GS4 415
#define NOTE_A4 440
#define NOTE_AS4 466
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_CS5 554
#define NOTE_D5 587
#define NOTE_DS5 622
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_FS5 740
#define NOTE_G5 784
#define NOTE_GS5 831
#define NOTE_A5 880
#define NOTE_AS5 932
#define NOTE_B5 988
#define NOTE_C6 1047
#define NOTE_CS6 1109
#define NOTE_D6 1175
#define NOTE_DS6 1245
#define NOTE_E6 1319
#define NOTE_F6 1397
#define NOTE_FS6 1480
#define NOTE_G6 1568
#define NOTE_GS6 1661
#define NOTE_A6 1760
#define NOTE_AS6 1865
#define NOTE_B6 1976
#define NOTE_C7 2093
#define NOTE_CS7 2217
#define NOTE_D7 2349
#define NOTE_DS7 2489
#define NOTE_E7 2637
#define NOTE_F7 2794
#define NOTE_FS7 2960
#define NOTE_G7 3136
#define NOTE_GS7 3322
#define NOTE_A7 3520
#define NOTE_AS7 3729
#define NOTE_B7 3951
#define NOTE_C8 4186
#define NOTE_CS8 4435
#define NOTE_D8 4699
#define NOTE_DS8 4978
#define CHOICE_OFF      0 //Used to control LEDs
#define CHOICE_NONE     0 //Used to check buttons
#define CHOICE_RED  (1 << 0)
#define CHOICE_GREEN    (1 << 1)
#define CHOICE_BLUE (1 << 2)
#define CHOICE_YELLOW   (1 << 3)
#define LED_RED     10
#define LED_GREEN   3
#define LED_BLUE    13
#define LED_YELLOW  5
// Button pin definitions
#define BUTTON_RED    9
#define BUTTON_GREEN  2
#define BUTTON_BLUE   12
#define BUTTON_YELLOW 6
// Buzzer pin definitions
#define BUZZER1  4
#define BUZZER2  7
// Define game parameters
#define ROUNDS_TO_WIN      13 //Number of rounds to succesfully remember before you win. 13 is do-able.
#define ENTRY_TIME_LIMIT   3000 //Amount of time to press a button before game times out. 3000ms = 3 sec
#define MODE_MEMORY  0
#define MODE_BATTLE  1
#define MODE_BEEGEES 2
// Game state variables
byte gameMode = MODE_MEMORY; //By default, let's play the memory game
byte gameBoard[32]; //Contains the combination of buttons as we advance
byte gameRound = 0; //Counts the number of succesful rounds the player has made it through
  //Setup hardware inputs/outputs. These pins are defined in the hardware_versions header file
  //Enable pull ups on inputs
  pinMode(BUTTON_RED, INPUT_PULLUP);
  pinMode(BUTTON_GREEN, INPUT_PULLUP);
  pinMode(BUTTON_BLUE, INPUT_PULLUP);
  pinMode(BUTTON_YELLOW, INPUT_PULLUP);
  pinMode(LED_RED, OUTPUT);
  pinMode(LED_GREEN, OUTPUT);
  pinMode(LED_BLUE, OUTPUT);
  pinMode(LED_YELLOW, OUTPUT);
  pinMode(BUZZER1, OUTPUT);
  pinMode(BUZZER2, OUTPUT);
  //Mode checking
  gameMode = MODE_MEMORY; // By default, we're going to play the memory game
  // Check to see if the lower right button is pressed
  if (checkButton() == CHOICE_YELLOW) play_beegees();
  // Check to see if upper right button is pressed
  if (checkButton() == CHOICE_GREEN)
    gameMode = MODE_BATTLE; //Put game into battle mode
    //Turn on the upper right (green) LED
    setLEDs(CHOICE_GREEN);
    toner(CHOICE_GREEN, 150);
    setLEDs(CHOICE_RED | CHOICE_BLUE | CHOICE_YELLOW); // Turn on the other LEDs until you release button
    while(checkButton() != CHOICE_NONE) ; // Wait for user to stop pressing button
    //Now do nothing. Battle mode will be serviced in the main routine
  play_winner(); // After setup is complete, say hello to the world
  attractMode(); // Blink lights while waiting for user to press a button
  // Indicate the start of game play
  setLEDs(CHOICE_RED | CHOICE_GREEN | CHOICE_BLUE | CHOICE_YELLOW); // Turn all LEDs on
  setLEDs(CHOICE_OFF); // Turn off LEDs
  delay(250);
  if (gameMode == MODE_MEMORY)
    // Play memory game and handle result
    if (play_memory() == true)
      play_winner(); // Player won, play winner tones
      play_loser(); // Player lost, play loser tones
  if (gameMode == MODE_BATTLE)
    play_battle(); // Play game until someone loses
//The following functions are related to game play only
// Play the regular memory game
// Returns 0 if player loses, or 1 if player wins
boolean play_memory(void)
  randomSeed(millis()); // Seed the random generator with random amount of millis()
  gameRound = 0; // Reset the game to the beginning
  while (gameRound < ROUNDS_TO_WIN)
    add_to_moves(); // Add a button to the current moves, then play them back
    playMoves(); // Play back the current game board
    // Then require the player to repeat the sequence.
    for (byte currentMove = 0 ; currentMove < gameRound ; currentMove++)
      byte choice = wait_for_button(); // See what button the user presses
      if (choice == 0) return false; // If wait timed out, player loses
      if (choice != gameBoard[currentMove]) return false; // If the choice is incorect, player loses
    delay(1000); // Player was correct, delay before playing moves
  return true; // Player made it through all the rounds to win!
// Play the special 2 player battle mode
// A player begins by pressing a button then handing it to the other player
// That player repeats the button and adds one, then passes back.
// This function returns when someone loses
boolean play_battle(void)
  gameRound = 0; // Reset the game frame back to one frame
  while (1) // Loop until someone fails
    byte newButton = wait_for_button(); // Wait for user to input next move
    gameBoard[gameRound++] = newButton; // Add this new button to the game array
      if (choice == 0) return false; // If wait timed out, player loses.
      if (choice != gameBoard[currentMove]) return false; // If the choice is incorect, player loses.
    delay(100); // Give the user an extra 100ms to hand the game to the other player
  return true; // We should never get here
// Plays the current contents of the game moves
void playMoves(void)
    toner(gameBoard[currentMove], 150);
    // Wait some amount of time between button playback
    // Shorten this to make game harder
    delay(150); // 150 works well. 75 gets fast.
// Adds a new random button to the game sequence, by sampling the timer
void add_to_moves(void)
  byte newButton = random(0, 4); //min (included), max (exluded)
  // We have to convert this number, 0 to 3, to CHOICEs
  if(newButton == 0) newButton = CHOICE_RED;
  else if(newButton == 1) newButton = CHOICE_GREEN;
  else if(newButton == 2) newButton = CHOICE_BLUE;
  else if(newButton == 3) newButton = CHOICE_YELLOW;
//The following functions control the hardware
// Lights a given LEDs
// Pass in a byte that is made up from CHOICE_RED, CHOICE_YELLOW, etc
void setLEDs(byte leds)
  if ((leds & CHOICE_RED) != 0)
    digitalWrite(LED_RED, HIGH);
    digitalWrite(LED_RED, LOW);
  if ((leds & CHOICE_GREEN) != 0)
    digitalWrite(LED_GREEN, HIGH);
    digitalWrite(LED_GREEN, LOW);
  if ((leds & CHOICE_BLUE) != 0)
    digitalWrite(LED_BLUE, HIGH);
    digitalWrite(LED_BLUE, LOW);
  if ((leds & CHOICE_YELLOW) != 0)
    digitalWrite(LED_YELLOW, HIGH);
    digitalWrite(LED_YELLOW, LOW);
// Wait for a button to be pressed.
// Returns one of LED colors (LED_RED, etc.) if successful, 0 if timed out
byte wait_for_button(void)
  long startTime = millis(); // Remember the time we started the this loop
  while ( (millis() - startTime) < ENTRY_TIME_LIMIT) // Loop until too much time has passed
    byte button = checkButton();
    if (button != CHOICE_NONE)
      toner(button, 150); // Play the button the user just pressed
      while(checkButton() != CHOICE_NONE) ;  // Now let's wait for user to release button
      delay(10); // This helps with debouncing and accidental double taps
      return button;
  return CHOICE_NONE; // If we get here, we've timed out!
// Returns a '1' bit in the position corresponding to CHOICE_RED, CHOICE_GREEN, etc.
byte checkButton(void)
  if (digitalRead(BUTTON_RED) == 0) return(CHOICE_RED);
  else if (digitalRead(BUTTON_GREEN) == 0) return(CHOICE_GREEN);
  else if (digitalRead(BUTTON_BLUE) == 0) return(CHOICE_BLUE);
  else if (digitalRead(BUTTON_YELLOW) == 0) return(CHOICE_YELLOW);
  return(CHOICE_NONE); // If no button is pressed, return none
// Light an LED and play tone
// Red, upper left:     440Hz - 2.272ms - 1.136ms pulse
// Green, upper right:  880Hz - 1.136ms - 0.568ms pulse
// Blue, lower left:    587.33Hz - 1.702ms - 0.851ms pulse
// Yellow, lower right: 784Hz - 1.276ms - 0.638ms pulse
void toner(byte which, int buzz_length_ms)
  setLEDs(which); //Turn on a given LED
  //Play the sound associated with the given LED
  switch(which)
  case CHOICE_RED:
    buzz_sound(buzz_length_ms, 1136);
  case CHOICE_GREEN:
    buzz_sound(buzz_length_ms, 568);
  case CHOICE_BLUE:
    buzz_sound(buzz_length_ms, 851);
  case CHOICE_YELLOW:
    buzz_sound(buzz_length_ms, 638);
  setLEDs(CHOICE_OFF); // Turn off all LEDs
// Toggle buzzer every buzz_delay_us, for a duration of buzz_length_ms.
void buzz_sound(int buzz_length_ms, int buzz_delay_us)
  // Convert total play time from milliseconds to microseconds
  long buzz_length_us = buzz_length_ms * (long)1000;
  // Loop until the remaining play time is less than a single buzz_delay_us
  while (buzz_length_us > (buzz_delay_us * 2))
    buzz_length_us -= buzz_delay_us * 2; //Decrease the remaining play time
    // Toggle the buzzer at various speeds
    digitalWrite(BUZZER1, LOW);
    digitalWrite(BUZZER2, HIGH);
    delayMicroseconds(buzz_delay_us);
    digitalWrite(BUZZER1, HIGH);
    digitalWrite(BUZZER2, LOW);
// Play the winner sound and lights
void play_winner(void)
  setLEDs(CHOICE_GREEN | CHOICE_BLUE);
  winner_sound();
  setLEDs(CHOICE_RED | CHOICE_YELLOW);
  winner_sound();
  winner_sound();
  winner_sound();
// This is just a unique (annoying) sound we came up with, there is no magic to it
void winner_sound(void)
  for (byte x = 250 ; x > 70 ; x--)
    for (byte y = 0 ; y < 3 ; y++)
      delayMicroseconds(x);
// Play the loser sound/lights
void play_loser(void)
  setLEDs(CHOICE_RED | CHOICE_GREEN);
  buzz_sound(255, 1500);
  setLEDs(CHOICE_BLUE | CHOICE_YELLOW);
// Show an "attract mode" display while waiting for user to press button.
void attractMode(void)
  while(1)
    setLEDs(CHOICE_RED);
    delay(100);
    if (checkButton() != CHOICE_NONE) return;
    setLEDs(CHOICE_BLUE);
    delay(100);
    delay(100);
    setLEDs(CHOICE_YELLOW);
    delay(100);
// The following functions are related to Beegees Easter Egg only
// Notes in the melody. Each note is about an 1/8th note, "0"s are rests.
int melody[] = {
  NOTE_G4, NOTE_A4, 0, NOTE_C5, 0, 0, NOTE_G4, 0, 0, 0,
  NOTE_E4, 0, NOTE_D4, NOTE_E4, NOTE_G4, 0,
  NOTE_D4, NOTE_E4, 0, NOTE_G4, 0, 0,
  NOTE_D4, 0, NOTE_E4, 0, NOTE_G4, 0, NOTE_A4, 0, NOTE_C5, 0};
int noteDuration = 115; // This essentially sets the tempo, 115 is just about right for a disco groove :)
int LEDnumber = 0; // Keeps track of which LED we are on during the beegees loop
// Do nothing but play bad beegees music
// This function is activated when user holds bottom right button during power up
void play_beegees()
  //Turn on the bottom right (yellow) LED
  toner(CHOICE_YELLOW, 150);
  setLEDs(CHOICE_RED | CHOICE_GREEN | CHOICE_BLUE); // Turn on the other LEDs until you release button
  setLEDs(CHOICE_NONE); // Turn off LEDs
  delay(1000); // Wait a second before playing song
  digitalWrite(BUZZER1, LOW); // setup the "BUZZER1" side of the buzzer to stay low, while we play the tone on the other pin.
  while(checkButton() == CHOICE_NONE) //Play song until you press a button
    // iterate over the notes of the melody:
    for (int thisNote = 0; thisNote < 32; thisNote++) {
      changeLED();
      tone(BUZZER2, melody[thisNote],noteDuration);
      // to distinguish the notes, set a minimum time between them.
      // the note's duration + 30% seems to work well:
      int pauseBetweenNotes = noteDuration * 1.30;
      delay(pauseBetweenNotes);
      // stop the tone playing:
      noTone(BUZZER2);
// Each time this function is called the board moves to the next LED
void changeLED(void)
  setLEDs(1 << LEDnumber); // Change the LED
  LEDnumber++; // Goto the next LED
  if(LEDnumber > 3) LEDnumber = 0; // Wrap the counter if needed
That's the way to go, make test code, or using example codes to gain knowledge, and verify correct hardware wiring.
Don't post snippets, cut outs, of the code. Know that every helper is a complete newbie to Your project and being able to read the entire code gives us a chance to understand the environment so to say.
Tell what You have working and what You want to achieve. Don't spend words on this or that program code statement, while, for, switch... It only pollutes the description, brings a lot of obstacle text to fastforward through.
Quoting: "Simon Says code"... Says.... All such should be told in commenting the code.
Note that no helper likes to watch tutorials, videos, to find out.
Very true. This is because the information density in most videos is very very light. They have to spin it out to make as long a video as possible in order to maximise the amount of money they get paid.
Thanks @Railroader for the tips. To clarify, I provided the links so people know where I got the original code. What I have working is the Simon-Says code in my original post (pasted again here). I don't know where to go next.
 Example sketch 16
 Oct. 7, 2014
 13 rounds.
 0.568ms pulse
* Public Constants
#define NOTE_B0 31
#define NOTE_C1 33
#define NOTE_CS1 35
#define NOTE_D1 37
#define NOTE_DS1 39
#define NOTE_E1 41
#define NOTE_F1 44
#define NOTE_FS1 46
#define NOTE_G1 49
#define NOTE_GS1 52
#define NOTE_A1 55
#define NOTE_AS1 58
#define NOTE_B1 62
#define NOTE_C2 65
#define NOTE_CS2 69
#define NOTE_D2 73
#define NOTE_DS2 78
#define NOTE_E2 82
#define NOTE_F2 87
#define NOTE_FS2 93
#define NOTE_G2 98
#define NOTE_A2 110
#define NOTE_B2 123
#define NOTE_C3 131
#define NOTE_D3 147
#define NOTE_E3 165
#define NOTE_F3 175
#define NOTE_G3 196
#define NOTE_A3 220
#define NOTE_B3 247
#define NOTE_C4 262
#define NOTE_D4 294
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_G4 392
#define NOTE_A4 440
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_D5 587
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_G5 784
#define NOTE_A5 880
#define NOTE_B5 988
#define LED_RED     10
#define LED_GREEN   3
#define LED_BLUE    13
#define BUZZER1  4
#define BUZZER2  7
  //Mode checking
  delay(250);
      return button;
  switch(which)
  case CHOICE_RED:
  case CHOICE_GREEN:
  case CHOICE_BLUE:
  case CHOICE_YELLOW:
  winner_sound();
  winner_sound();
  winner_sound();
  winner_sound();
  while(1)
    delay(100);
    delay(100);
    delay(100);
    delay(100);
int melody[] = {
void play_beegees()
      changeLED();
      noTone(BUZZER2);
Okey. Such code is mostly large and/or advanced a lot more than example code for a sensor, a motor, an LCD etc... Reading and understanding code made by other people is many times more difficult than coding it yourself. Okey, technical details, syntax etc is often valuable.
You refer to libraries that are likely not known or used by all helpers. Good information but, in general, not easy to grab for all helpers.
What is Your real question? What works and what differs from Your goal?
Spinning out. Here (in Sweden) we name it "boil soup out of a nail".
@ Railroader, thank you so much for helping me form this question properly. The code posted is working, but it uses momentary push buttons for input and I would like to use the MPR121 module instead. I just attempted a mash-up of the cap sense example code provided by the library and my working Simon-Says code, but am getting a 'lvalue required as left operand of assignment' error.
 Example sketch 16
 Oct. 7, 2014
 13 rounds.
 0.568ms pulse
Below code adapted from the Adafruit MPR121 Cap Sensor Library
#include <Wire.h>
#include "Adafruit_MPR121.h"
#include <ezButton.h>
#ifndef _BV
#define _BV(bit) (1 << (bit))
#endif
// You can have up to 4 on one i2c bus but one is enough for testing!
Adafruit_MPR121 cap = Adafruit_MPR121();
// Keeps track of the last pins touched
// so we know when buttons are 'released'
uint16_t lasttouched = 0;
uint16_t currtouched = 0;
* Public Constants
#define NOTE_B0 31
#define NOTE_C1 33
#define NOTE_CS1 35
#define NOTE_D1 37
#define NOTE_DS1 39
#define NOTE_E1 41
#define NOTE_F1 44
#define NOTE_FS1 46
#define NOTE_G1 49
#define NOTE_GS1 52
#define NOTE_A1 55
#define NOTE_AS1 58
#define NOTE_B1 62
#define NOTE_C2 65
#define NOTE_CS2 69
#define NOTE_D2 73
#define NOTE_DS2 78
#define NOTE_E2 82
#define NOTE_F2 87
#define NOTE_FS2 93
#define NOTE_G2 98
#define NOTE_A2 110
#define NOTE_B2 123
#define NOTE_C3 131
#define NOTE_D3 147
#define NOTE_E3 165
#define NOTE_F3 175
#define NOTE_G3 196
#define NOTE_A3 220
#define NOTE_B3 247
#define NOTE_C4 262
#define NOTE_D4 294
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_G4 392
#define NOTE_A4 440
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_D5 587
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_G5 784
#define NOTE_A5 880
#define NOTE_B5 988
#define LED_RED     9
#define LED_GREEN   8
#define LED_BLUE    3
#define LED_YELLOW  4
#define BUTTON_RED    7
#define BUTTON_GREEN  6
#define BUTTON_BLUE   5
#define BUTTON_YELLOW 2
#define BUZZER1  10
#define BUZZER2  11
  //Cap Sense Library
  while (!Serial) { // needed to keep leonardo/micro from starting too fast!
    delay(10);
  Serial.println("Adafruit MPR121 Capacitive Touch sensor test");
  // Default address is 0x5A, if tied to 3.3V its 0x5B
  // If tied to SDA its 0x5C and if SCL then 0x5D
  if (!cap.begin(0x5A)) {
    Serial.println("MPR121 not found, check wiring?");
    while (1);
  Serial.println("MPR121 found!");
  //Mode checking
//Cap Sense Code
// Get the currently touched pads
  currtouched = cap.touched();
  for (uint8_t i=0; i<12; i++) {
    // it if *is* touched and *wasnt* touched before, alert!
    if ((currtouched & _BV(i)) && !(lasttouched & _BV(i)) ) {
      Serial.print(i); Serial.println(" touched");
    // if it *was* touched and now *isnt*, alert!
    if (!(currtouched & _BV(i)) && (lasttouched & _BV(i)) ) {
      Serial.print(i); Serial.println(" released");
    //Test this Switch Case statement to assign
switch (i)
  case 1:
    BUTTON_RED=1;
  case 2:
    BUTTON_GREEN=1;
  case 3:
    BUTTON_BLUE=1;
  case 4:
    BUTTON_YELLOW;
  // reset our state
  lasttouched = currtouched;
  // comment out this line for detailed data from the sensor!
  return;
  // debugging info, what
  Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t\t 0x"); Serial.println(cap.touched(), HEX);
  Serial.print("Filt: ");
    Serial.print(cap.filteredData(i)); Serial.print("\t");
  Serial.print("Base: ");
    Serial.print(cap.baselineData(i)); Serial.print("\t");
  // put a delay so it isn't overwhelming
  delay(100);
  //end of cap sense code
  delay(250);
      return button;
  switch(which)
  case CHOICE_RED:
  case CHOICE_GREEN:
  case CHOICE_BLUE:
  case CHOICE_YELLOW:
  winner_sound();
  winner_sound();
  winner_sound();
  winner_sound();
  while(1)
    delay(100);
    delay(100);
    delay(100);
    delay(100);
int melody[] = {
void play_beegees()
      changeLED();
      noTone(BUZZER2);
Okay, making progress but need some help on the void loop (). When I place the following code (for reading from the cap sense board) at the beginning of the loop, the game won't start. When I place it at the end of the loop, the cap sense input won't read.
Code for cap sense that needs to be in the loop:
  //Cap Sense Code
      valTouched = i;
       Serial.print(i); Serial.println(" =valTouched");
  // reset our state
  return;
  delay(100);
Full code that is almost working:
 Example sketch 16
 Oct. 7, 2014
 13 rounds.
 0.568ms pulse
#include <Wire.h>
#ifndef _BV
#endif
uint16_t valTouched = 0;  //set up a variable to hold the state of the button (0=no buttons touched, 1=button 1 touched, 2=button 2 touched, etc.)
* Public Constants
#define NOTE_B0 31
#define NOTE_C1 33
#define NOTE_CS1 35
#define NOTE_D1 37
#define NOTE_DS1 39
#define NOTE_E1 41
#define NOTE_F1 44
#define NOTE_FS1 46
#define NOTE_G1 49
#define NOTE_GS1 52
#define NOTE_A1 55
#define NOTE_AS1 58
#define NOTE_B1 62
#define NOTE_C2 65
#define NOTE_CS2 69
#define NOTE_D2 73
#define NOTE_DS2 78
#define NOTE_E2 82
#define NOTE_F2 87
#define NOTE_FS2 93
#define NOTE_G2 98
#define NOTE_A2 110
#define NOTE_B2 123
#define NOTE_C3 131
#define NOTE_D3 147
#define NOTE_E3 165
#define NOTE_F3 175
#define NOTE_G3 196
#define NOTE_A3 220
#define NOTE_B3 247
#define NOTE_C4 262
#define NOTE_D4 294
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_G4 392
#define NOTE_A4 440
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_D5 587
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_G5 784
#define NOTE_A5 880
#define NOTE_B5 988
#define LED_RED     9
#define LED_GREEN   8
#define LED_BLUE    3
#define BUZZER1  10
#define BUZZER2  11
  //Cap Sense Library
    delay(10);
    while (1);
  //Mode checking
  //Cap Sense Code
      valTouched = i;
  // reset our state
  return;
  delay(100);
  delay(250);
      return button;
//////////////////////////////BUTTON CHOICE////////////////////////////////////////////////
  if (valTouched == 1) return(CHOICE_RED);
  switch(which)
  case CHOICE_RED:
  case CHOICE_GREEN:
  case CHOICE_BLUE:
  case CHOICE_YELLOW:
  winner_sound();
  winner_sound();
  winner_sound();
  winner_sound();
  while(1)
    delay(100);
    delay(100);
    delay(100);
    delay(100);
int melody[] = {
void play_beegees()
      changeLED();
      noTone(BUZZER2);
SOLVED: I modified the checkButton function in the original Simon Says code to store the pin value as valTouched. Then set up an 'if else' statement to return the correct button color choice based on the pin associated with that color. Everything works great now.
checkButton Function looks like this:
    //Cap Sense Code
       valTouched = i;
         if (valTouched==1) {
    Serial.println("Red Button");
    return(CHOICE_RED); }
  else if (valTouched==2) {
    Serial.println("Blue Button");
    return(CHOICE_BLUE); }
  else if (valTouched==3) {
    Serial.println("Green Button");
    return(CHOICE_GREEN);  }
  else if (valTouched==4) {
    Serial.println("Yellow Button");
    return(CHOICE_YELLOW);}
  // reset our state
Full Code:
 Example sketch 16
 Oct. 7, 2014
 13 rounds.
 0.568ms pulse
#include <Wire.h>
#ifndef _BV
#endif
* Public Constants
#define NOTE_B0 31
#define NOTE_C1 33
#define NOTE_CS1 35
#define NOTE_D1 37
#define NOTE_DS1 39
#define NOTE_E1 41
#define NOTE_F1 44
#define NOTE_FS1 46
#define NOTE_G1 49
#define NOTE_GS1 52
#define NOTE_A1 55
#define NOTE_AS1 58
#define NOTE_B1 62
#define NOTE_C2 65
#define NOTE_CS2 69
#define NOTE_D2 73
#define NOTE_DS2 78
#define NOTE_E2 82
#define NOTE_F2 87
#define NOTE_FS2 93
#define NOTE_G2 98
#define NOTE_A2 110
#define NOTE_B2 123
#define NOTE_C3 131
#define NOTE_D3 147
#define NOTE_E3 165
#define NOTE_F3 175
#define NOTE_G3 196
#define NOTE_A3 220
#define NOTE_B3 247
#define NOTE_C4 262
#define NOTE_D4 294
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_G4 392
#define NOTE_A4 440
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_D5 587
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_G5 784
#define NOTE_A5 880
#define NOTE_B5 988
#define LED_RED     9
#define LED_GREEN   8
#define LED_BLUE    3
#define BUZZER1  10
#define BUZZER2  11
  //Cap Sense Library
    delay(10);
    while (1);
  //Mode checking
  delay(250);
      return button;
    //Cap Sense Code
       valTouched = i;
  // reset our state
  switch(which)
  case CHOICE_RED:
  case CHOICE_GREEN:
  case CHOICE_BLUE:
  case CHOICE_YELLOW:
  winner_sound();
  winner_sound();
  winner_sound();
  winner_sound();
  while(1)
    delay(100);
    delay(100);
    delay(100);
    delay(100);
int melody[] = {
void play_beegees()
      changeLED();
      noTone(BUZZER2);
