Simon the Game-LEDs are out of control
Hi Guys,
I have a Problem. i'm trying to rebuild the game SIMON with Arduino (for those who don#
't know what game I mean, please lokk at the link: Simon (game) - Wikipedia)
Here the Code:
int switch1 = 11;
int switch2 = 10;
int switch3= 9;
int switch4 = 8;
int led1= 5;
int led2 = 4;
int led3= 3;
int led4= 2;
int turn = 0;
int input1= LOW;
int input2= LOW;
int input3= LOW;
int input4 = LOW;
int randomArray[100]; //Intentionally long to store up to 100 inputs (doubtful anyone will get this far)
int inputArray[100];
 pinMode(led1, OUTPUT);
 pinMode(led2, OUTPUT);
 pinMode(led3, OUTPUT);
 pinMode(led4, OUTPUT);
 pinMode(switch1, INPUT);
 pinMode(switch2, INPUT);
 pinMode(switch3, INPUT);
 pinMode(switch4, INPUT);
 randomSeed(analogRead(0)); //Added to generate "more randomness" with the randomArray for the output function
for (int y=0; y<=99; y++){ //For statement to loop through the output and input functions
  output();
  input();
void output() { //function for generating the array to be matched by the player
  for (int y=turn; y <= turn; y++){ //Limited by the turn variable
   Serial.println(""); //Some serial output to follow along
   Serial.print("Turn: ");
   Serial.print(y);
   Serial.println("");
   randomArray[y] = random(1, 5); //Assigning a random number (1-4) to the randomArray[y], y being the turn count
   for (int x=0; x <= turn; x++){
     Serial.print(randomArray[x]);
     if (randomArray[x] == 1) {  //if statements to display the stored values in the array
       digitalWrite(led1, HIGH);
       digitalWrite(led1, LOW);
       delay(100);
     if (randomArray[x] == 2) {
       digitalWrite(led2, HIGH);
       digitalWrite(led2, LOW);
       delay(100);
     if (randomArray[x] == 3) {
       digitalWrite(led3, HIGH);
       digitalWrite(led3, LOW);
       delay(100);
     if (randomArray[x] == 4) {
       digitalWrite(led4, HIGH);
       digitalWrite(led4, LOW);
       delay(100);
void input() { //Function for allowing user input and checking input against the generated array
 for (int x=0; x <= turn;){ //Statement controlled by turn count
   input1 = digitalRead(switch1);
   input2 = digitalRead(switch2);
   input3 = digitalRead(switch3);
   input4 = digitalRead(switch4);
   if (input1 == HIGH){ //Checking for button push
     delay(200);
     inputArray[x] = 1;
     delay(50);
     Serial.print(" ");
     Serial.print(1);
     if (inputArray[x] != randomArray[x]) { //Checks value input by user and checks it against
       fail();                              //the value in the same spot on the generated array
     }                                      //The fail function is called if it does not match
     x++;
   if (input2 == HIGH){
     delay(200);
     inputArray[x] = 2;
     delay(50);
     Serial.print(" ");
     Serial.print(2);
       fail();
     x++;
   if (input3 == HIGH){
     delay(200);
     inputArray[x] = 3;
     delay(50);
     Serial.print(" ");
     Serial.print(3);
       fail();
     x++;
   if (input4 == HIGH){
     delay(200);
     inputArray[x] = 4;
     delay(50);
     Serial.print(" ");
     Serial.print(4);
       fail();
     x++;
 turn++; //Increments the turn count, also the last action before starting the output function over again
void fail() { //Function used if the player fails to match the sequence
 for (int y=0; y<=5; y++){ //Flashes lights for failure
  delay(200);
  delay(200);
 turn = -1; //Resets turn value so the game starts over without need for a reset button
void loop() { //Unused void loop(), though for some reason it doesn't compile without this /shrug
The LEDs are connected with GND and the PINs which are mentiooned before in the code
The Buttons are also connected with GND and the PINS and 5 V
Now to my Problem: When I upload the code to the board. The Leds are going crazy. Firstly one or two shortly glow and then all 4 Ledds glow like there was an error.
Do anyone know whats going wrong? Would be very nice and great if you could help me.
PS: please excuse my bad english i'am no native speaker.
Greetz
The first thing that you need to do is to add some current limiting resistors to those LEDs. LEDs draw as much current as possible, which is not good for your Arduino.
Your input function is not a blocking function. If there are no buttons pressed when the function is called, it zips through input in just over half a second. Most of that time is in the delay() call at the end. Is that what you really want?
Okey, I add the resistors to every LED.
No thats not what I want, how can I make it better?
Make it wait for an input on each pass through loop
   do
   } while(input1 == LOW && input2 == LOW && input3 == LOW && input4 == LOW);
You could add a timeout to this, too, so that the user had to respond within a given amount of time.
What value?
http://www.thebox.myzen.co.uk/Tutorial/LEDs.html
What value?
220 Ohms
Cool :slight_smile:
