simple 433 mhz test not working
Hello, I just bought a pair of 433 mhz transmitter and receiver, and wanted to test them if they are working or not. I downloaded the Radiohead library and did everything in the tutorial TUTORIAL: How to set up wireless RF (433Mhz) Transmitter Receiver Module - Arduino Quick Simple - YouTube . Yet I can not see any output in the com port. I attached the pictures of the setups. Also here is the code itself
for receiver:
#include <RH_ASK.h>
#ifdef RH_HAVE_HARDWARE_SPI
#include <SPI.h> // Not actually used but needed to compile
#endif
RH_ASK driver(2000, 13, 5, 0);
#ifdef RH_HAVE_SERIAL
Serial.begin(115200); // Debugging only
#endif
if (!driver.init())
Serial.println("init failed");
#else
#endif
uint8_t buf[RH_ASK_MAX_MESSAGE_LEN];
uint8_t buflen = sizeof(buf);
if (driver.recv(buf, &buflen)) // Non-blocking
//int i;
// Message with a good checksum received, dump it.
driver.printBuffer("Got:", buf, buflen);
For transmitter:
#include <RH_ASK.h>
#endif
RH_ASK driver(2000, 2, 13, 0);
if (!driver.init())
const char * msg = "hello";
driver.send((uint8_t *)msg, strlen(msg));
driver.waitPacketSent();
delay(200);
(Moderator - added images for you)
Try this as a test - disconnect the radio data line, and connect Tx directly to Rx.
See if you can receive messages that way.
When you can, then go back and put the radio modules in again.
Be sure both units have 17mm antenna wires on them (can be simple piece of 30AWG wirewrap wire) for 433 MHz.
The LEDs are so bright it makes it difficult to see how things are wired up.
What do these lines indicate:?
RH_ASK driver(2000, 13, 5, 0); // RX
RH_ASK driver(2000, 2, 13, 0); // TX
