Simple Alert Project using Bluetooth
We have this simple test project where in the objective to simply alert the person if its too dark(LDR). This is the diagram:
LDR ⬇
Audio File ➡ SD Card Module ➡ Arduino ➡ Bluetooth Module ➡ Bluetooth Headset
We already have: Arduino(clone) SD Card Module HC-05 Bluetooth Module (Master & Slave) Bluetooth Headset
We are done on the implementation of the LDR but we ran into problems implementing the Bluetooth part.
Any ideas and criticism are welcome! :) :)
Can you explain little more on the Bluetooth portion?
Are you having issues setting/configuring the bluetooth portion? or you got past that and having issues actually using it?
Yes. We've done the basic set-up but unfortunately we don't know how to "send" the audio to the bluetooth headset using the bluetooth module
That is because you can't. A HC-05 Bluetooth Module is not capable of running the audio mode of bluetooth.
Grumpy_Mike: That is because you can't. A HC-05 Bluetooth Module is not capable of running the audio mode of bluetooth.
Oh dang. Can you recommend what module should we use for that part?
Sorry don't know one.
