Thanks a lot for your help spatula & zoomkat.
spatula:
But I can’t see why one would want to send POST requests to the Arduino server, instead of using GET.
The reason of this is that I need to send a large amount of data +20 parameters, I did not find nice to send that amount of data via GET request. Not saying that it is a bad thing to do.
zoomkat:
zoomkat, what about reading POSTed parameters, that´s what I need to do.
Server test code that will echo posted data to the serial monitor.
A simple web server using an Arduino Wiznet Ethernet shield.
For Arduino IDE V1.0 only. Previous IDE versions require mods to this code.
Original code created 18 Dec 2009
by David A. Mellis
modified 4 Sep 2010
by Tom Igoe
modified 18 Jan 2012
by Tim Dicus
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
//address will look like http://192.168.1.102:84 when submited
byte mac = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip( 192,168,1,102 );
IPAddress gateway( 192,168,1,1 );
IPAddress subnet( 255,255,255,0 );
//IPAddress dns( 192,168,1,1 );
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(84);
// set SPI SS pins on w5100 and SD
pinMode(10,OUTPUT);
digitalWrite(10,HIGH);
pinMode(4,OUTPUT);
digitalWrite(4,HIGH);
// start the SD interface here if you want.
// Add the SD.h library above
// SD.begin(4);
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip, dns, gateway, subnet);
// disable w5100 SPI so SD SPI can work with it
delay(2000);
server.begin();
Serial.println(“setup finished”);
// listen for incoming clients
if (client) {
Serial.println(“Client”);
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
while(client.available()) {
char c = client.read();
// if you’ve gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == ‘\n’ && currentLineIsBlank) {
// Here is where the POST data is.
Serial.write(client.read());
Serial.println(“Sending response”);
// send a standard http response header
client.println(“HTTP/1.0 200 OK”);
client.println(“Content-Type: text/html”);
client.println();
client.println(“TEST OK!”);
//form added to send data from browser and view received data in serial monitor
client.println("<FORM ACTION=“http://192.168.1.102:84” METHOD=“post”>");
client.println(“Name: <INPUT TYPE=“TEXT” NAME=“Name” VALUE=”" SIZE=“25” MAXLENGTH=“50”>
client.println(“Email: <INPUT TYPE=“TEXT” NAME=“Email” VALUE=”” SIZE=“25” MAXLENGTH=“50”>
client.println(”<INPUT TYPE=“SUBMIT” NAME=“submit” VALUE=“Sign Me Up!”>");
client.println("");
client.println("
client.stop();
else if (c == ‘\n’) {
// you’re starting a new line
else if (c != ‘\r’) {
// you’ve gotten a character on the current line
currentLineIsBlank = false;
Serial.println(“Disconnected”);
That worked perfectly! Getting params as expected inside the request:
Name=test&Email=asd%40asd&submit=Sign+Me+Up%21
