Simple arduino LED program
Hi , I have 1 receiver (( my receiver is a 5v Arduino PRO MICRO )) box and 2 transfer box
Transfer 1 has 2 bottom , bottom 1 and bottom 2
If I push bottom 1 it transfer it to receiver box and receiver gets that and send order to windows to press F1 bottom on keyboard ( I use keyboard library )
And , If I push bottom 2 it transfer it to receiver box and receiver gets that and send order to windows to press F2 bottom on keyboard
Transfer 2 has 2 bottom , bottom 3 and bottom 4
And it is the same as transfer box 1 but uses** **F6 and F7 Bottom
it works great
What I need is when I push bottom 1 , a simple 3v LED light gets ON too (( on the transfer Box1 and on the receiver Box in same time )) and when I release the bottom it gets OFF
Just that
if only the receiver Box LED works is enough
I send the codes for receiver BOX and Transfer box 1 for u
Thanks you
Receiver Box code
#include <Keyboard.h>
#include <RF24Network.h>
#include <RF24.h>
#include <SPI.h>
RF24 radio(7,8);
RF24Network network(radio);
const uint16_t this_node = 00;
const uint16_t other_node = 01;
unsigned int laser_state=0;
const unsigned long my_interval = 500;
unsigned long last_sent;
unsigned int income=0;
void setup(void)
  pinMode(9,INPUT_PULLUP);
  SPI.begin();
  radio.begin();
  network.begin(90,this_node);
void loop(void){
  network.update();
  if ( network.available() ) {
    RF24NetworkHeader header;
    network.read(header,&income,sizeof(income));
    if(income==1){
      Serial.println('a');
      Keyboard.press(KEY_F1);
      income=0;
    if(income==2){
      Serial.println('b');
      Keyboard.press(KEY_F2);
      income=0;
    if(income==3){
      Serial.println('c');
      Keyboard.press(KEY_F6);
      income=0;
    if(income==4){
      Serial.println('d');
      Keyboard.press(KEY_F7);
      income=0;
    Keyboard.releaseAll();
  unsigned long now = millis();
  if ( now - last_sent >= my_interval  )
//    Serial.print("pin ");
//    Serial.println(digitalRead(9));
    last_sent = now;
    laser_state = digitalRead(9);
    RF24NetworkHeader header(other_node);
    bool ok = network.write(header,&laser_state,sizeof(laser_state));
Transfer 1 Box code
#include <RF24.h>
#include <SPI.h>
RF24 radio(8,7);
const uint16_t this_node = 03;
const uint16_t other_node = 00;
const unsigned long interval = 50;
unsigned int b1=1;
unsigned int b2=1;
unsigned int d1=1;
unsigned int d2=2;
void setup(void)
//  Serial.begin(9600);
  pinMode(6,INPUT_PULLUP);
  pinMode(10,INPUT_PULLUP);
  SPI.begin();
  radio.begin();
void loop(void){
  network.update();
  if ( now - last_sent >= interval  )
    last_sent = now;
    b1 = digitalRead(6);
    b2 = digitalRead(10);
    if(b1==1){
//      Serial.println("b1 is on");
      bool ok = network.write(header,&d1,sizeof(d1));
    if(b2==0){
//      Serial.println("b2 is on");
      bool ok = network.write(header,&d2,sizeof(d2));
4 posts were merged into an existing topic: A simple arduino program
