Simple Bluetooth Controlled RGB LED
Hi All,
I’m really new to this - I’m trying to get an RGB LED to be controlled via Bluetooth using an Arduino Uno.
#include <SoftwareSerial.h>
#include <Wire.h>//Include libraries: SoftwareSerial & Wire
SoftwareSerial BT(11,12);
//Define PIN11 & PIN12 as RX and TX pins
//RGB LED Pins
int
PIN_RED = 3;
int
PIN_GREEN = 5;
int
PIN_BLUE = 6;
//RED LED at Pin 13
int
RED_LED = 13;
String RGB =
//store RGB code from BT
String RGB_Previous =
"255.255.255)"
//preserve previous RGB color for LED switch on/off, default White
String ON =
"ON"
//Check if ON command is received
String OFF =
"OFF"
//Check if OFF command is received
boolean RGB_Completed =
false
void
setup() {
//Arduino serial port baud rate:9600
BT.begin(9600);
//My HC-05 module default baud rate is 9600
RGB.reserve(30);
pinMode(RED_LED, OUTPUT);
//Set pin13 as output for LED,
// this LED is on Arduino mini pro, not the RGB LED
void
loop() {
//Read each character from Serial Port(Bluetooth)
while
(BT.available()){
char
ReadChar = (
char
)BT.read();
// Right parentheses ) indicates complet of the string
if
(ReadChar ==
RGB_Completed =
true
RGB += ReadChar;
//When a command code is received completely with ')' ending character
if
(RGB_Completed){
//Print out debug info at Serial output window
Serial.print(
"RGB:"
Serial.print(RGB);
Serial.print(
"     PreRGB:"
Serial.println(RGB_Previous);
if
(RGB==ON){
digitalWrite(13,HIGH);
RGB = RGB_Previous;
//We only receive 'ON', so get previous RGB color back to turn LED on
Light_RGB_LED();
if
(RGB==OFF){
digitalWrite(13,LOW);
RGB =
"0.0.0)"
//Send OFF string to turn light off
Light_RGB_LED();
//Turn the color according the color code from Bluetooth Serial Port
Light_RGB_LED();
RGB_Previous = RGB;
//Reset RGB String
RGB =
RGB_Completed =
false
//end if of check if RGB completed
// end of loop
void
Light_RGB_LED(){
int
SP1 = RGB.indexOf(
int
SP2 = RGB.indexOf(
, SP1+1);
int
SP3 = RGB.indexOf(
, SP2+1);
String R = RGB.substring(0, SP1);
String G = RGB.substring(SP1+1, SP2);
String B = RGB.substring(SP2+1, SP3);
Serial.print(
"R="
Serial.println( constrain(R.toInt(),0,255));
Serial.print(
"G="
Serial.println(constrain(G.toInt(),0,255));
Serial.print(
"B="
Serial.println( constrain(B.toInt(),0,255));
//Light up the LED with color code
//**2014-09-21
//Because these RGB LED are common anode (Common positive)
//So we need to take 255 to minus R,G,B value to get correct RGB color code
analogWrite(PIN_RED,  (255-R.toInt()));
analogWrite(PIN_GREEN, (255-G.toInt()));
analogWrite(PIN_BLUE,  (255-B.toInt()));
I am following a tutorial however, when I verify the sketch I keep getting these errors:
In function ‘void loop()’:
sketch_dec27b:132: error: ‘Light_RGB_LED’ was not declared in this scope
Light_RGB_LED();
sketch_dec27b:148: error: ‘Light_RGB_LED’ was not declared in this scope
Light_RGB_LED();
sketch_dec27b:156: error: ‘Light_RGB_LED’ was not declared in this scope
Light_RGB_LED();
exit status 1
Any help would be greatly appreciated thanks!
Wow, the spacing in that makes it just awful to read.
I cleaned it up some
//RGB LED Pins
int PIN_RED = 3;
int PIN_GREEN = 5;
int PIN_BLUE = 6;
//RED LED at Pin 13
int RED_LED = 13;
String RGB = "";
String RGB_Previous = "255.255.255)";
String ON = "ON";
String OFF = "OFF";
boolean RGB_Completed =false;
void
setup() {
    BT.begin(9600);
    RGB.reserve(30);
void
loop() {
  while    (BT.available()){
    char      ReadChar = (
    char      )BT.read();
    if
      (ReadChar ==       ')'      )
      RGB_Completed =       true        ;
  RGB += ReadChar;
if
(RGB_Completed){
  Serial.print(  "RGB:"   );
  Serial.print(RGB);
  Serial.print(  "     PreRGB:"   );
  if    (RGB==ON){
    RGB = RGB_Previous;
    Light_RGB_LED();
  else      if
      (RGB==OFF){
      RGB =       "0.0.0)"      ;
      Light_RGB_LED();
    Light_RGB_LED();
    RGB_Previous = RGB;
  //Reset RGB String
  RGB = "";
  RGB_Completed = false;
// end of loop
void
Light_RGB_LED(){
  int    SP1 = RGB.indexOf(  '.'    );
  int    SP2 = RGB.indexOf(  '.'   , SP1+1);
  int    SP3 = RGB.indexOf( '.'   , SP2+1);
  Serial.print(  "R="    );
  Serial.print(  "G="    );
  Serial.print(  "B="   );
  //**2014-09-21
and it compiles in 1.0.6 ok.
This part, with multiple char declarations, looks funny to me, like something got left out:
    char      ReadChar = (
    char      )BT.read();
    if
      (ReadChar ==       ')'      )
  RGB += ReadChar;
Thanks, I found a lot of spaces too which I had to clean up.
I have copied your code into 1.6.7 but I’m still getting the : Light_RGB_LED was not declared in this scope error.
This is where I got the code from: Link
Based on my limited experience, I would recommend that you NOT copy and paste code. Most importantly, it teaches you nothing, but it also can be a royal PITA to debug.
I am guessing the culprit here is a typo, like the omission of a curly bracket or a semicolon. You could hunt it down, but instead try rewriting the code yourself, using your reference code as exactly that, a reference.
Try just writing the outline of what the code will do in comments as a first step, IN YOUR OWN WORDS. Then go back and rewrite the code from your reference. The parts you are certain of go ahead and write on your own without looking at the reference code.
This should force you to understand what the code is doing and thus make it much easier to debug.
