Im playing around with a robotic arm. It has 2 servos (one moves the arm and the other open/closes the claw). It works but it jitters a bit on both servos because of noise. What I mean is both servos jitter or move around or wiggle a bit if i just let it sit there. How do I work around that?
This is my sketch:
Controlling a servo position using a potentiometer (variable resistor)
by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
modified on 8 Nov 2013
by Scott Fitzgerald
http://www.arduino.cc/en/Tutorial/Knob
#include <Servo.h>
Servo myservo1; // create servo object to control a servo gyro
Servo myservo2; // create servo object to control a servo claw
int potpin1 = 0; // analog pin used to connect the pot1
int val1; // variable to read the value from the analog pin 0
int button = 0; // variable to read the value from the analog pin 2
const int buttonPin = 2; // the number of the pushbutton pin
int buttonState; // the current reading from the input pin
int buttonFlag = 0; // button never been pressed
myservo1.attach(9); // attaches the servo1 on pin 9 to the servo object
myservo2.attach(10); // attaches the servo2 on pin 10 to the servo object
pinMode(buttonPin, INPUT);
myservo2.write(10); // open claw
buttonState = 1; // state = open
val1 = analogRead(potpin1); // reads the value of the potentiometer (value between 0 and 1023)
Serial.println(val1);
val1 = map(val1, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
myservo1.write(val1); // sets the servo position according to the scaled value
delay(15); // waits for the servo to get there
button = digitalRead(buttonPin);
Serial.println(button);
if (button == 1) {
Serial.println("Button Clicked");
buttonFlag = 1;
toggleClaw();
void toggleClaw() {
if (buttonState == 1) { //claw is open
closeClaw();
} else {//if (buttonState == 0)
openClaw();
void openClaw() {
buttonState = 1; //record that buttonState is now open-1
myservo2.write(10); // sets the servo position according to the scaled value
void closeClaw() {
buttonState = 0; //state now closed
myservo2.write(170);
How would I toggle when the button BECOMES pressed?
By now, you should be quite familiar with all the example code that comes with the IDE. If you are not, either put the Arduino away OR become familiar with the examples. There IS one that covers that question.
I was trying to remember how I solved similar issues in iOS game programming when a bullet struck a target the first time and not having to fire it again with every subsequent collision after that as the bullet “traversed” the target polygon. I remembered we use flags to note when a collision had first occurred and after that was set to true, detection ceased for a while. I just wasnt able to work out the details.
I found the Debounce example, thanks. I have a small doubt. In this bit of code:
// if the button state has changed:
if (reading != buttonState) {
buttonState = reading;
// only toggle the LED if the new button state is HIGH
if (buttonState == HIGH) {
ledState = !ledState;
after we detect the recently read state ‘reading’ ISNOT equal to the current ‘buttonState’, it must mean the button was touched. We then update the ‘buttonState’ with the new ‘reading’ state.
Since the ledState starts out LOW, if the new value is HIGH, then we toggle the LED…but what does:
do, exactly? Im not sure what we are doing here. Is it saying to set ledState to the opposite of whatever it is? Does that work in this case because its a value that can only be LOW or HIGH? Btw, how does that work since we defined it as an int (which can take any + whole numerical value) instead of opposing LOW-HIGH values?
by Scott Fitzgerald
#include <Servo.h>
int clawState = HIGH; // the claw start out open
int lastButtonState = LOW; // the previous reading from the input pin
long lastDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 50; // the debounce time; increase if the output flickers
openClaw();
//Start by sweeping servo1
sweepServo();
//Read state of buttonPin
int reading = digitalRead(buttonPin);
Serial.println(reading);
// If the switch changed, due to noise or pressing:
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
clawState = !clawState;
//should i just call openClaw() here???????????
//set claw to latest logically defined state
toggleClaw();
//save most recent state
lastButtonState = reading;
void sweepServo() {
void toggleClaw() {
if (clawState == 1) { //claw is open
closeClaw();
openClaw();
void openClaw() {
//clawState = 1; //record that buttonState is now open-1
void closeClaw() {
//clawState = 0; //state now closed
