Simple C programming Question
I have gone through the example sketches and have been successful, even modifying some for different delays and pins.
Then, I've merged the Blink, Servo and Parallax PIR Rev B Motion Detector Sketches into a test sketch. Right now, I am trying to detect motion and turn on/off the onboard LED. No matter what value is returned from the motion detector via a digitalRead, the LED is always turned on. Either my variable assignment or the logical test is wrong, but at this time, I can't determine which.
The debug output is as follows. Whenever the integer value is 0, I am expecting the message to be "detected LOW".
detected HIGH
1   detected HIGH
1   detected HIGH
0   detected HIGH
0   detected HIGH
0   detected HIGH
0   detected HIGH
0   detected HIGH
My code is attached below:
// Sketch to blink prop eyes when someone approaches.
// Behavior can be modified depending on how long they stay
// Test version blinks LED
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int motionPin = 2;  // analog pin used to connect the motion detector
int motionVal;      // variable to read the value from the analog pin
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
  // initialize the servo on pin 9
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
// Allow the motion detector to warm up.
  delay(20000);
  motionVal=digitalRead(motionPin);
  Serial.println(motionVal);
  if (motionVal = 1) {
    digitalWrite(led,HIGH);
    Serial.println("detected HIGH");
  if (motionVal = 0) {
    digitalWrite(led,LOW);
    Serial.println("detected LOW");
  delay(200);
(deleted)
if (motionVal = 1) ...
if (motionVal = 0)  ....
You are using the assigment operator (=) instead of the equals operator (==). Change it to the following ...
if (motionVal == 1) ...
if (motionVal == 0)  ....
Ah hah!
I've figured it out, by looking at other examples. My comparison operators were wrong. The test should have been:
The sketch is working as expected now.
Thanks to you all. Our replies crossed in the ether, but I wanted to thank you for your answers.
