Simple calculation fails
I'm embarassed to post this question here. But I am not able to calculate a common divider / multiplier operation. I'm stuck and I hope that someone can help me. I can't figure out that strange behaviour:
Here some tryouts. Result should be 35,98, or better 36 (%).
first try:
Serial.println((2913/8096)*100);
=> results in 0
second try:
char t[4];
float i = (2913/8096)*100;
sprintf(t, "%d", i);
Serial.println(t);
=> results in 0.
third try:
char t[4];
int i = (2913/8096)*100;
itoa((2913/8096)*100, t, 10);
Serial.println(t);
=> results in 0.
I've changed i to be float, int, long. Result is the same.
What am I doing wrong?! This is incredible I cant find my mistake :~
Thanks for your help guys
-Florian
Serial.println((2913L * 100L) /8096L); ?
Thank you. It works fine.
I've learned something new today :) -> IntegerConstants!
Next step is to learn about float constants.
Serial.println((2913.0/8096.0)*100.0);
Will NOT print 0.
mesa: Thank you. It works fine.
And hopefully you've learned that dividing an integer by a larger integer will give you zero.
