Hi all!
I'm trying to build a simple LED fade function, and I've got it working just how I want it to, but I've fallen at the last hurdle... I have the following code that generates a number from 0-255 which is the "master brightness"
void RampUp() {
if (alreadyon == 0) {
for (int i = 270; i < 450; i++) { // 360 degrees of an imaginary circle.
float angle = radians(i); // Converts degrees to radians.
brightness = (255 / 2) + (255 / 2) * sin(angle); // Generates points on a sign wave.
delay(5); // Delay between each point of sine wave.
I have 3 sets of LEDs I'm controlling, and I would like them to end up at different maximum brightnesses as such:
int PointerBrightness = 25;
int FrontBrightness = 20;
int RearBrightness = 50;
So I want to make some code like this:
void RampUp() {
analogWrite(PointerLEDPin, (PointerBrightness/255)*brightness);
analogWrite(FrontLEDPin, (FrontBrightness/255)*brightness);
analogWrite(RearLEDPin, (RearBrightness/255)*brightness);
valuet = (PointerBrightness/255)*brightness;
However, when I add the "(PointerBrightness/255)*brightness" I get nothing from the LED. using the serial monitor I see that the result of the calculation is 0. What am I doing wrong here..??
