Simple Calculations with If Statements not working
I am trying to convert RPM's of my car to degrees to work with a nextion UI. However for some reason the 1000-1999 range does not work. When I put the if statement:
if (1000 < RPM <= 2000){ degRPM = (RPM - 1000) * .015 + 348; return(degRPM); }
at the bottom of the function then all the calculations work other than the 1000-1999. If I keep it how it is formatted as below, then all the numbers are wrong... I can't seem to figure out what is causing this.
int calcRPM(int RPM){
  int degRPM = 0;
  String strRPM = String(RPM);
  myNex.writeStr("t0.txt", strRPM);
  if (RPM <= 1000){
      degRPM = RPM * .015 + 333;
      return(degRPM);
      return(degRPM);
  if (2000 < RPM <= 3000){
      return((RPM - 2000) * .029 + 3);
  if (3000 < RPM <= 4000){
      degRPM = (RPM - 3000) * .028 + 32;
      return(degRPM);
  if (4000 < RPM <= 5000){
      degRPM = (RPM - 4000) * .027 + 60;
      return(degRPM);
  if (5000 < RPM <= 6000){
      degRPM = (RPM - 5000) * .029 + 87;
      return(degRPM);
  if (6000 < RPM <= 7000){
      degRPM = (RPM - 6000) * .029 + 116;
      return(degRPM);
  if (7000 < RPM <= 8000){
      degRPM = (RPM - 7000) * .032 + 145;
      return(degRPM);
  if (8000 < RPM <= 9000){
      degRPM = (RPM - 8000) * .032 + 177;
      return(degRPM);
  return degRPM;
if (RPM > 1000 && RPM <= 2000){
Rather than fixing your syntax, you can use 'else' causes to simplify:
  if (RPM <= 1000) {
  else if (RPM <= 2000) {
  else if (RPM <= 3000) {
      degRPM = (RPM - 2000) * .029 + 3;
  else if (RPM <= 4000) {
  else if (RPM <= 5000) {
  else if (RPM <= 6000) {
  else if (RPM <= 7000){
  else if (RPM <= 8000) {
  else if (RPM <= 9000) {
  return degRPM;
  myNex.writeStr("t0.txt", String(RPM));
  if (RPM <= 1000) return RPM * .015 + 333;
  else if (RPM <= 2000) return (RPM - 1000) * .015 + 348;
  else if (RPM <= 3000) return (RPM - 2000) * .029 + 3;
  else if (RPM <= 4000) return (RPM - 3000) * .028 + 32;
  else if (RPM <= 5000) return (RPM - 4000) * .027 + 60;
  else if (RPM <= 6000) return (RPM - 5000) * .029 + 87;
  else if (RPM <= 7000) return (RPM - 6000) * .029 + 116;
  else if (RPM <= 8000) return (RPM - 7000) * .032 + 145;
  else return (RPM - 8000) * .032 + 177;
Thank you SO MUCH! worked perfectly!
