Simple Calculator (5110 LCD + Ps2 Keyboard )
I Wrote this code using LCD 5110 Library and Ps2keyboar Library
Is a simple calculator (+ - * / operations) , uses RPN notation
its display the user input like a desk calculator
(the digits roll to left, and last number digit appear on the right)
//Simple Calculator By Endrio Lázaro
// This program requires a Nokia 5110 LCD module.
// It is assumed that the LCD module is connected to
// the following pins using a levelshifter to get the
// correct voltage to the module.
//  SCK - Pin 8
//  MOSI - Pin 9
//  DC  - Pin 10
//  RST - Pin 11
//  CS  - Pin 12
//PS2 Keyboard (for arduino uno, irq pin must be 2 or 3)
//DataPin = 4;
// IRQpin = 3;
// this program use LCD5110_NumberFonts (C)2013 Henning Karlsen
// see more: http://www.henningkarlsen.com/electronics
#include <String.h>;
#include <LCD5110_Basic.h>
#include <PS2Keyboard.h>
const int DataPin = 4;
const int IRQpin = 3;
PS2Keyboard keyboard;
LCD5110 myGLCD(8,9,10,11,12);
extern uint8_t SmallFont[];
extern uint8_t MediumNumbers[];
extern uint8_t BigNumbers[];
char c='1';
//mathematic operations
float Stack;
//Total
float Input;
//new number entered by user
String Stacks;
// to manipulate the stack
String Inputs;
// to manipulate new input
int Size;
//control if user has entered a new number
char lastOper;
// last number in the stack
float lastNum;
void printLcd()
    beep(50);
    myGLCD.clrScr();
    myGLCD.setFont(MediumNumbers);
    myGLCD.printNumF(Stack/100, 2, RIGHT, 24);
    //display total bellow display
    if (Size!=0)
        Input = Inputs.toInt();
        myGLCD.printNumF(Input/100, 2, RIGHT, 9);
        //display user input above
        myGLCD.printNumF(lastNum/100, 2, RIGHT, 9);
    myGLCD.setFont(SmallFont);
    myGLCD.print("total", LEFT, 45);
void printLcdTotal()
    myGLCD.clrScr();
    myGLCD.printNumF(Stack/100, 2, CENTER, 24);
    myGLCD.print("TOTAL", LEFT, 0);
    beep(600);
void beep(unsigned char delayms)
    analogWrite(6, 80);
    // Almost any value can be used except 0 and 255
    // experiment to get the best tone
    delay(delayms);
    // wait for a delayms ms
    analogWrite(6, 0 );
    // 0 turns it off
    delay(delayms);
    pinMode(6, OUTPUT);
    keyboard.begin(DataPin, IRQpin);
    Serial.println("Keyboard Test:");
    myGLCD.InitLCD();
    printLcd();
    myGLCD.invert(true);
    if (keyboard.available())
        // read the next key
        char c = keyboard.read();
        int t = c;
        Serial.print(t);
        //if key is a number, put in the last position of input string
        if ((c=='1')||(c=='2')||(c=='3')||(c=='4')||(c=='5')||(c=='6')||(c=='7')||(c=='8')||(c=='9')||(c=='0'))
            if (Size <=5 )
                //max size of string
                Inputs= Inputs+c;
                Size++;
        // if ENTER is pressed do ADDICTION
        if (c==13)
            Serial.print(Size);
            if(Size==0)
                //if no number entered by user, uses last entered number
                Stack += lastNum;
                Stack += Inputs.toInt();
                lastNum = Inputs.toInt();
                Inputs = "";
                //reset user input
                Size = 0;
            myGLCD.invert(false);
            //invert screen if minus operator is used
        // If + is pressed do subtraction
        if (c=='+')
            Serial.print(Size);
            //debug
            if(Size==0)
                Stack += lastNum;
                //if no number entered use last number entered
                Inputs = "";
                //reset user input
                Size = 0;
        // do * operation
        if (c=='*')
            //multiply Stack by the number entered by user;
            Stack *= Inputs.toInt();
            Inputs = "";
            //reset user input
            Size = 0;
        // do * operarion (not complete, may give a by 0 division)
        if (c=='/')
            //divide Stack by the number entered by user;
            Stack /= Inputs.toInt();
            Inputs = "";
            //reset user input
            Size = 0;
        printLcd();
        // print to lcd
        //if comma is pressed, give total;
        if (c==46)
            printLcdTotal();
            Inputs = "";
            //reset user input
            Size = 0;
calcularora.ino (4.51 KB)
@endrio,
Nice, and RPN... Cool. When I wrote my calculator,
http://forum.arduino.cc/index.php?PHPSESSID=vmf2gmq25jmd7brfum41p9ish2&topic=147550.0
I just used serial I/O but the LCD and real keyboard is a nice touch.
More pics...
http://www.hackster.io/rayburne/scientific-calculator
Bravo!
Ray
