Simple CHAR concat?
Hi, I have been fumbling around with this code without any joy.... anyone able to put me right?
I have a char "loggerName" and I want to add ".CSV" to make a new char "fileName.CSV" (needs to stay as a CHAR).
I have tried lots of options but keen to keep it simple but just cannot figure out why this will not compile?
char loggerName[10] = "AAAA_01";
char fileName[15] = (loggerName += ".CSV");
Use strcat()
Because there is no += operater for char arrays.
Thanks Arrch, I have tried using that but it produces a string which is not accepted by the next bit in the code:
SD.open(fileName, FILE_WRITE);
What does a serial.print tell you is in your filename variable? Also, post your code.
Not compiling is the issue I'm having.... below are the relevant code snippets and compile error:
Code:
char loggerName[10] = "AMAS_01";
File dataFile = SD.open(fileName, FILE_WRITE);
invalid operands of types 'char[10]' and 'const char [5] to binary 'operator+'
It's telling you you can't add character arrays together like that. Here's one way to do it:
char fileName[15];
strcpy(filename, loggerName);
strcat(filename,".CSV");
Thanks - still getting a compile error?
This message:
expected cpnstructor, destructor, or type conversion before '(' token
This line highlighted:
there was a typo in that code. The variable has a capital N
char fileName[15];
strcpy(fileName, loggerName);
strcat(fileName,".CSV");
ooops... should have spotted that one :slight_smile:
Unfortunatley still getting the same compile problem (Arduino 0.22) for both the strcpy & strcat lines?
Ahhh.... got it.
I had the strcpy & strcat in the bit before void setup () (whatever that section is called?) - moved it to setup and it all works nicely.... thanks all for your help, appreciated :slight_smile:
point5:
Ahhh.... got it.
A good example of why it's best to post ALL your code.
Just wanted to send a big thank you out to wildbill and Tom Carpenter et al for their help here. It FINALLY allowed me to manipulate my char arrays (4 of different sizes into one long string for my loop to run through) so I could display them on a serLCD from sparkfun, 16 chars at a time. Basically, simulating a scrolling effect on just a single line.
Thanks again, y'all rock.
