Simple CLI example
Hi All,
I've just started playing with Arduino and I wrote a simple command line interface (CLI) sketch for testing a pin in an interactive manner. I know that shells exist for arduino, etc... this is just a demo :wink:
This lets you turn on, off, and blink pin 13 from a terminal program (hyperterm, PuTTY, etc.)
This isn't meant to an application in an of itself, but more of a stepping stone. Just an example of how to use a serial connection and turn on, off, and blink an LED.
More info (and a prettier presentation of the code) can be found at this short article I wrote:
http://digital-salvage.net/?p=36
I'm currently playing with an LCD and a GPS. Will post code examples of that as well once I get it finished, if folks are interested.
Here is the code:
/* simplecli version 001
 * C. Cosentino 2009 - http://digital-salvage.net/?p=36
 *  This software is licensed under the CC-GNU GPL version 2.0
 *     See: http://creativecommons.org/licenses/GPL/2.0/
 *  Simple CLI example that demonstrates how to use serial to perform
 *  interactive commands (turning a pin on or off) via a terminal application.
#define ledPin 13           // define a pin for the LED
#define MCHARS 8            // max characters to accept
#define ENTER 13            // byte value of the Enter key (LF)
char inStr[MCHARS];         // the input string
int inByte = 0;             // byte being read in
int strCount = 0;           // counter for the string
int blink = 0;              // toggle for blink routine
int value = LOW;            // Initial Pin value of LED for blink
        pinMode(ledPin, OUTPUT);  // sets ledPin as an OUTPUT pin
      Serial.begin(9600);        // opens serial port, sets data rate to 9600 bps
        Serial.print(">");        // print  prompt when serial is ready
  if(Serial.available()) {                 // if bytes are available to be read
    inByte = Serial.read();                // read the byte
    Serial.print(char(inByte));            // echo byte entered to terminal as a char
    if(inByte != ENTER) {                  // if the byte is not a NEWLINE
      inStr[strCount] = char(inByte);      // add the byte to the "String" array
      strCount++;                          // increase the item string count
  if(inByte == ENTER || strCount >= MCHARS) {  // if enter was pressed or max chars reached
    Serial.flush();                         // flush the serial data (overkill?)
    Serial.println("");                     // print a newline
    if (strcmp(inStr, "blink") == 0){       // string compare, does entered text == blink?
      if (blink == 1) {                     // if so, if blink is 1, pin was already blinking
        Serial.println("LED Off");          // print to the terminal
        digitalWrite(ledPin, LOW);          // make certain LED is in LOW state
        blink = 0;                          // toggle blink variable
      } else {                              // if it was not 1...
        Serial.println("LED Blinking");          // print to the terminal
        blink = 1;                          // ... then set to 1
    } else if (strcmp(inStr, "on") == 0){   // string compare, does entered text == on?
      digitalWrite(ledPin, HIGH);           // if so, then turn on ledPin
      Serial.println("LED On");              // print to the terminal
      blink = 0;
    } else if (strcmp(inStr, "off") == 0){  // string compare, does entered text == off?
      digitalWrite(ledPin, LOW);            // if so, then turn off ledPin
      blink = 0;
    } else {                                // if the input text doesn't match any defined above
      Serial.println("Invalid.");           // echo back to the terminal
    strCount = 0;                           // get ready for new input... reset strCount
    inByte = 0;                             // reset the inByte variable
    for(int i = 0; inStr[i] != '\0'; i++) { // while the string does not have null
      inStr[i] = '\0';                      // fill it with null to erase it
    Serial.print(">");                      // print the prompt
  if(blink == 1) {                          // if blink
    delay(100);                             // wait for it! (you could use millis if/then here)
    if(value == LOW) {                      // if pin is LOW
      value = HIGH;                         // set it for HIGH
    } else {                                // otherwise it is HIGH
      value = LOW;                          // so set it fot low
    digitalWrite(ledPin, value);            // send the command to the pin
Edit: Any comments or suggests are much appreciated. I have not touched C in almost 15 years :slight_smile:
