Any help appreciated with this simple 4 button code
Objective: Arduino Mega - It has a connected 4 relay board and 2 x RC type servos
PART THAT WORKS OK : if I press buttons 1 or 2 I get a relay activation and the 2 servos move to the pre-determined positions
PART THAT DOES NOT WORK : If I press buttons 3 or 4 I get no relay or servo activity
The button and relay connectivity is good as I can run a simple 4 button/4 relay code without issues.
Although the code compiles OK on the IDE I ran it through an online emulator and got this result:
error report :
sketch.ino: In function 'void setup()':
sketch.ino:16:1: error: a function-definition is not allowed here before '{' token
sketch.ino:31:1: error: a function-definition is not allowed here before '{' token
Error during build: exit status 1
Here is the actual code: THANKS ALL..!!
#include <Servo.h>
Servo servo1;
Servo servo2;
int relay1 = 2; //Amp CH1 relay
int relay2 = 3; //Amp CH2 relay
int relay3 = 4; //Amp CH3 relay
int relay4 = 5; //Amp CH4 relay
int button1 = 8; //CH1 Button
int button2 = 9; //CH2 Button
int button3 = 10; //CH3 Button
int button4 = 11; //CH4 Button
// Initialize digital output pins for relays:
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT_PULLUP);
pinMode(button3, INPUT_PULLUP);
pinMode(button4, INPUT_PULLUP);
servo1.attach(6); //set pin to servo mode
servo2.attach(7); //set pin to servo mode
bool button1State ;
button1State = digitalRead(button1);
if(button1State == LOW)
digitalWrite(relay1, LOW);
digitalWrite(relay2, HIGH);
digitalWrite(relay3, HIGH);
digitalWrite(relay4, HIGH);
for (int i = 0; i < 60; i++) {
servo1.write(i);
servo2.write(i);
delay(20); //speed of servos
bool button2State ;
button2State = digitalRead(button2);
if(button2State == LOW)
digitalWrite(relay1, HIGH);
digitalWrite(relay2, LOW);
servo1.write(i);
servo2.write(i);
bool button3State ;
button3State = digitalRead(button3);
if(button3State == LOW)
digitalWrite(relay3, LOW);
servo1.write(i);
servo2.write(i);
bool button4State ;
button4State = digitalRead(button4);
if(button4State == LOW)
servo1.write(i);
servo2.write(i);
