I did read a big portion of posts here, and did learn many things, but now I'm loosing a fill rouge, on my mature head.
Can someone write a simple code for stepper rail, which I plan to use with an old winding machine, to lead a wire?
The goal is- reading turns from axis with either magnetic or optical sensor, and Arduino should move nSteps per turn (depend of a thickness of wire ) and reverse direction every time that hit the limit switches. (it could be single or two button switch)
Any ideas.
I will be grateful for everything!
Opps.. I already have a driver for motor, so have to start with PUL and DIR.
Stepper works fine, with sample code I Uploaded, while I Using a AccelStepper library.
After long time, I have try again to do something with my old winding machine.
I need a wire movement, for which I have a Nema17 stepper on rail.
I decided to use manually switches for direction of stepper with HY-DIV268N driver to simplify code, and give to myself a little more time to learn.
Now I use this sketch for rotary encoder, but everything I do further just make mess in sketch and my head.
// The pins the quadrature encoder is connected.
// We connect the second signal of the encoder to pin 4.
// int.1 is free for other use.
int in_a = 2;
int in_b = 4;
// The number of pulses per revolution
// depends on your index disc!!
unsigned int pulsesperturn = 36;
// The total number of revolutions
int revolutions = 0;
// Initialize the counter
volatile int pulses = 0;
void count() {
// This function is called by the interrupt
// If in_b is HIGH increment the counter
// otherwise decrement it
if (digitalRead(in_b)) {
pulses++;
else {
pulses--;
pinMode(in_a, INPUT);
pinMode(in_b, INPUT);
attachInterrupt(0, count, RISING);
revolutions = pulses / pulsesperturn;
// Here you can output the revolutions, e. g. once a second
Serial.println(revolutions);
delay(50);
// Now I would like to implement followed action
// 1.For each turn, set (n) output pulses, to use with stepper driver.
// 2.Wait for next Turn to repeat actions
I would like to get (n, 1-50) number of pulses on digital PWM pin for each turn, because the diameter of wire is (n) mm,
I still hope someone can give me some hint, so I can use it in practice.
later I will upgrade it to avoid mechanical switches.
It's a long time since your first post. I wonder if there is anything useful in stepper motor basics.
Can you explain a bit more about how you plan to use the encoder. What causes it to turn and what is the relationship between the encoder and the motor.
I don't understand what the "digital PWM pin" is for?
