Hi folks, I'm new into programming and I'm trying to make this code work, which is part of a larger program that controls a couple of relays instead of LEDs.
What I need to do now is: when a button is pressed (i.e. a microswitch), the program should turn OFF an LED and wait some seconds to turn it on again.
I can't use the 'while' control structure since it will stop the running loop and therefore stop the whole code from controlling other stuff.
Check this out:
const int ledPin = 13;
int led = HIGH;
const int puls1Pin = 30;
int puls1;
int inmersionB1 = 3000;
unsigned long inicioInmersionB1;
pinMode(ledPin, OUTPUT);
pinMode(puls1Pin, INPUT);
digitalWrite(puls1Pin, HIGH);
puls1 = digitalRead(puls1Pin);
if (puls1 == LOW) {
led = LOW;
inicioInmersionB1 = millis();
program1;
digitalWrite(ledPin, led);
void program1() {
if ((currentMillis - inicioInmersionB1) > inmersionB1) {
if (led == HIGH)
led = LOW;
int led = HIGH;
int puls1;
pinMode(puls1Pin, INPUT); <- Use INPUT_PULLUP instead
digitalWrite(puls1Pin, HIGH); Get rid of this, not needed if you use INPUT_PULLUP
if (puls1 == LOW) { <- No Debounce?
led = LOW;
program1; <- Though this compiles, it is not doing what you want, try adding ( ) and take it out of that IF statement otherwise it will only check when the button is pressed.
digitalWrite(ledPin, led); Not really needed here, better if it is in the IF statement
void program1() {
if (led == HIGH)
led = LOW; But the button turns the LED OFF, shouldn't this make it HIGH HERE
digitalWrite(ledPin, led); <- Move this...
Alright, first of all thank you for your advice! I introduced the changes you suggested and a few more. Started using a library that stores the time elapsed. This one.
Here are the changes, now the led turns off alright, but it wont turn on after the specified time.
Any suggestions?
#include <elapsedMillis.h>
int led = HIGH;
int puls1;
pinMode(puls1Pin, INPUT_PULLUP);
digitalWrite(ledPin, HIGH); [b]//If i get rid of this, the led starts OFF : :o [/b]
if (puls1 == LOW) {
delay(10);
led = LOW;
elapsedMillis inicioInmersionB1;
program1();
void program1() {
if (led == LOW)
led = HIGH;
Because I wasn't sure how to store millis() properly. Now It's clear, thank you again!
This code isn't working properly yet though, I need program1() to be called only if the button is pressed. Otherwise the LED starts OFF after 3 seconds it turns on for itself. However moving it into the 'if' statement doesn't do the trick.
I need the program to wait while the button is pressed, for 3 seconds and then turn the LED back ON.
int led = HIGH;
int puls1;
if (puls1 == LOW)
delay(10);
led = LOW;
program1(); //Now i put it into the 'if' statement, but looks like the program1() is not called at all since the led doesnt turn back on!
void program1()
if ((millis() - inicioInmersionB1) >= inmersionB1)
if (led == LOW)
led = HIGH;
when you do the above, you call
your program1() function a few uS later.
therefore:
will never be true.
Start thinking about how the code executes and the time that things happen.
You can use:
Serial.println(" I got here ");
at strategic locations, to prove if the sketch gets to where you think it gets to.
HazardsMind:
How is your button wired? Right now it is set to go LOW when pressed, otherwise it is HIGH.
The code worked when I posted it. The LED was on and when I brought pin 30 to ground, the LED went off, 3 seconds passed and it went back on again.
Thank you once more, button is wired as yours. But when I bring pin 30 to ground, the program turns the LED OFF indefinitely. When I release it, it stays OFF for 3 more seconds, then it turns ON.
Think of the button as a microswitch for some motor. When the switch is activated (the motor touches it and brings it to ground), it should turn the motor OFF and then after 3 seconds, turn it back ON so the switch is released. Do I make myself more clear?
LarryD:
therefore:
will never be true.
You can use:
Hi! thank you for your reply. I fail to see why
HazardsMind:
If someone else doesn't answer you, then I will do it in the morning. It is 1:03 AM here and I don't want to get back out of bed right now.
Thank you very much man, very appreciated! Good night.
In your post #4 you run this line as long as the switch is low:
You then call program1() a few uS later so:
Will not be true as inmersionB1 is 3000 or 3seconds.
The next time through loop() if the switch is still closed you again:
So once again:
is not true.
If the switch opens and goes HIGH there is no way to get to program1().
LarryD:
So once again:
is not true.
Thank you LarryD, now I understand perfectly why that approach won't work. Then how can I set the time stored on inicioInmersionB1 to be the one when the button is just pushed? I need to set that time once, not at every loop...
Let me get something straight.
Your motor runs. May be driving a threaded rod?
At some point a switch is closed. Do to the position of a traveler on the rod?
When the switch first closes you want the motor to stop. The switch stays closed?
After 3 seconds the motor starts. Does the switch open?
LarryD:
Remember there is something called switch bounce.
Thank you LarryD, that is exactly what is happening here. Should work like this: Motor runs until some traveler attached to it closes a switch and makes the motor stop. Then after 3 seconds, the motor runs again, opening the switch.
Check this out! I think I figured out how to solve it! This code works -almost- perfect, it doesn't work every time I push the button, most of the times, but not every time.
It seems like I need to debounce the switch. I'm trying to find out how to fix it. Any suggestions??
int led = HIGH;
int puls1;
if (puls1 == HIGH && led == HIGH)
button();
else if (puls1 == LOW && led == LOW)
program1();
int button()
if (puls1 == LOW)
delay(10);
led = LOW;
void program1()
if (led == LOW)
led = HIGH;
Solved guys! Thank you very much for your help! This is the way I solved. I followed LarryD's advice and researched about StateChangeDetection, found this and figured out how to make my code work. Thank you both, LarryD and HazardsMind, you pointed me in the right direction.
Here's the code:
int led = HIGH;
int puls1 = 0;
int ultpuls1 = 0;
long lastDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 50; // the debounce time; increase if the output flickers
button();
program1();
int button()
delay(10);
// compare the buttonState to its previous state
if (puls1 != ultpuls1) {
if (puls1 == LOW) {
led = LOW;
// save the current state as the last state,
//for next time through the loop
ultpuls1 = puls1;
void program1()
if (led == LOW)
led = HIGH;
