Hello everyone ![]()
This program is simply a calculator that I have developed< THIS CODE IS NOT MINE>.
I am trying to edit this code so that when I for example add 1+2
the display will show 3 right? Cool, here is what I wanna do. I want the calculator
to be able to lets say multiply the output(3) *2 and it should show 6.
With this code I will have to reset the calculator every time I want to use the last output in a new
equation.
#include <LiquidCrystal.h> //import lcd library
#include <Keypad.h> //import keypad libraryLiquidCrystal lcd(5, 4, 3, 2, 1, 0); //lcd pins
const byte ROWS = 4; // four rows
const byte COLS = 4; // four columns//define the keymap
char keys [ROWS] [COLS] = {
{'1', '2', '3', '+'},
{'4', '5', '6', '-'},
{'7', '8', '9', '*'},
{'X', '0', '=', '/'}
byte rowPins[ROWS] = {
9 ,8 ,7 ,6}; //connect keypad ROW1, ROW2, ROW3, ROW4 to these arduino pins
byte colPins[COLS] = {
13, 12, 11, 10}; //connect keypad COL1, COL2, COL3, COL4 to these arduino pins//create the keypad
Keypad myKeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );//variables declaration
boolean valOnePresent = false;
boolean next = false;
boolean final = false;
String num1, num2;
int ans;
char op;void setup(){
lcd.begin(16,2);
lcd.setCursor(2,0);
lcd.print("Calculator by:!");
lcd.setCursor(0,1);
lcd.print("Hadi M. Shabara");
delay(2500);
lcd.clear(); //clears the LCD screen and positions the cursor in the upper-left corner.
}void loop(){
char key = myKeypad.getKey();if (key != NO_KEY && (key=='1'||key=='2'||key=='3'||key=='4'||key=='5'||key=='6'||key=='7'||key=='8'||key=='9'||key=='0')){
if (valOnePresent != true){
num1 = num1 + key;
int numLength = num1.length();
lcd.setCursor(15 - numLength, 0); //to adjust one whitespace for operator
lcd.print(num1);
else {
num2 = num2 + key;
int numLength = num2.length();
lcd.setCursor(15 - numLength, 1);
lcd.print(num2);
final = true;
}else if (valOnePresent == false && key != NO_KEY && (key == '/' || key == '*' || key == '-' || key == '+')){
if (valOnePresent == false){
valOnePresent = true;
op = key;
lcd.setCursor(15,0); //operator on right corner
lcd.print(op);
}else if (final == true && key != NO_KEY && key == '='){
if (op == '+'){
ans = num1.toInt() + num2.toInt();
else if (op == '-'){
ans = num1.toInt() - num2.toInt();
else if (op == '*'){
ans = num1.toInt() * num2.toInt();
else if (op == '/'){
ans = num1.toInt() / num2.toInt();
lcd.clear();
lcd.autoscroll();
lcd.print(ans);
lcd.noAutoscroll();
else if (key != NO_KEY && key == 'X'){
lcd.clear();
final = false;
num1 = "";
num2 = "";
ans = 0;
op = ' ';
