Simple Coding for a Servo: Is this correct format?
Is this the correct format to tell a servo to go to a certain degree mark and hold?
     pos = 91;
    myservo.write(pos);
    delay(23);
Right now I think... that's telling the servo to go to 91 degrees and hold. I believe it's working but it seems like I hear the servo chattering (position holding I assume). Am I doing something wrong or is this normal behavior?
Is there a way to tell it to not hold position? The reason being that I leave the circuit on and I'd rather not burn the motor out while it's resting since there's obviously no need to leave it holding position.
thanks in advance! :)
Yes.
A servo is an electric motor with some control hardware to turn it off at a specific position. If the servo drifts from that position, it gets driven back to that position.
Servo.detach();
Really? It's not obvious to me. Usually servos DO something. That means holding a specific position.
Perfect and thanks! Is there a way to reattach the servo? I can detach it but then reattaching it I have to restart the program to get it to reattach. I’d like to reattach it within the main void loop.
Just call attach again
Hmmm, I called the attach again in the main loop:
 myservo.attach(9);
and when I compiled it gave an error. to give a background, there were no errors in compiling before I put this in the main loop. So something’s not being liked with this code.
 myservo.attach(9);
[glow]...[/glow]
The compiler doesn’t like the highlighted bit.
That was just representing the ... (or etc etc) worth of functional code that rambles on from there.
It has a hint, too. But, since you missed it, I'll spell it out. Post all of your code.
It has a hint
It has indeed*, thanks PaulS.
There was nothing syntactically wrong with the “attach”, so the problem does indeed lie with the “…”
*Sometimes I think I’m too damned subtle for my own (and others’) good.
Well I guess I need the hint spelled out for me. I'm not a programmer. Actually this is my first program that has actually done anything real or useful.
Sorry for my lack of knowledge here.
ok… lol. Sorry.
the … you’re joking about being my program. I’m reading too far into things. :slight_smile:
I'm reading too far into things.
Or too little.
Where's your code?
Got it figured out. Turns out it was a semicolon missing as best as I can tell. It now works.
Here is the code:
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
void loop()  // Program begins here.
while (buttonState == HIGH)
  // read the state of the Relay value:
  buttonState = digitalRead(buttonPin);
  myservo.attach(9);
  // if relay is NOT high exit program
if (buttonState != HIGH)
//Main Program
for (q = 0; q <=3; q += 1)
  for(pos = slowleft; pos >= slowright; pos -= 1)
    myservo.write(pos);
    delay(23);
  for(pos = slowright; pos < slowleft; pos+=1)
    myservo.write(pos);
    delay(23);
exit:
     pos = 91;
    myservo.write(pos);
    delay(23);
    myservo.detach();
Here is the code:
Are you somehow allergic to posting the whole code?
  myservo.attach(9);
I can't imagine the state of "buttonPin" has changed much in that short time.
