Hi. I'm working on a wirelessly controlled Arduino robot. I'm currently working on the remote controller part.
I'm using 2 joysticks to control 2 DC motors on the robot. (only the X position of the joystick is used)
I've written a simple function that takes the joystick's X position, maps it between 0 and 255 and decides the direction of each motor.
I noticed that the Arduino is reading small values (like 1, 2, 3), so I decided to add an If statement to my function. It just checks if the reading is between -5 and 5 to eliminate noise. The problem is that this if statement is executed even if the reading is out of this range.
For example -5 <= leftX <= 5
is true even if leftX
is 24.
Here's my function:
void calcMotorSpeeds(int leftX, int rightX){
if(-5 <= leftX <= 5){
//This code always executes
leftDirection = 0;
leftS = 0;
return;
if(-5 <= rightX <= 5){
rightDirection = 0;
rightS = 0;
return;
if(leftX > 0){
leftDirection = 1;
} else if (leftX < 0){
rightDirection = 2;
rightDirection = 0;
rightS= 0;
return;
if(rightX > 0){
leftDirection = 1;
} else if (rightX < 0){
rightDirection = 2;
rightDirection = 0;
rightS = 0;
return;
leftS = map(abs(leftX), 0, 100, 0, 255);
rightS = map(abs(rightX), 0, 100, 0, 255);
leftDirection, rightDirection, rightS, leftS are global variables.
I'm using a joystick library.
