Simple Counter Issue
I have a simple sketch that I want to light an LED strip when a sensor is activated. This first time the sensor is activated, I want the lights to turn red, the next time green and the next time blue. I created a simple counter using the following code, but it's not working right. At the beginning of the loop, I check to see if the counter is equal to 4 and if it is, I set it back down to 0.
When the counter equals 1 - I want the "red" code loop to play, when the counter equals 2, i want the green loop to play, etc...
I thought my logic below was sound, but it just cycles through all the loops when the sensor is activated. I printed the value of the counter to try and troubleshoot, but it only prints 0.
  if(digitalRead(sensor)==HIGH)
    if (counter=4) {
      counter =0;
     Serial.println(counter);
    counter = counter++;
    digitalWrite(ledPin, HIGH);
    strip.setBrightness(50);
  if (counter=1){
    red(); }
     if (counter=2){
    green(); }
    if (counter=3){
    blue(); }
Any help would be appreciated.
  if (counter=1){
     if (counter=2){
    if (counter=3){
Trifecta of oops.
    if (counter=4) {
With a bonus.
Hint: this is correct.
But even with the = vs == fixes, won't it need to look at the sensor having just gone high, not being high, ala the StateChangeDetection example?
Yes.
should be
counter++;
Thanks the == did the trick, I wasn't aware of the difference between = and == but a quick Google solved that.
Did you fix the
What colour do you want when the counter is 0?
