Hello, I builded a small counter that uses an infrared sensor to count objects on a conveyor.
However i want the counter to send the number of the counted object by network into a database.
Here is the code i use for counter to display the number on LCD:
int buttonPin = 2; // the pin that the pushbutton is attached to
// Variables will change:
int buttonPushCounter = -1; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
// initialize serial communication:
clearScreen();
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button
// wend from off to on:
buttonPushCounter++;
clearScreen();
Serial.print("Numar placute: ");
Serial.println(buttonPushCounter);
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
void clearScreen(){
Serial.write(byte(0x7C));
Serial.write(byte(0x00));
And here is the code that i think i have to combine with the previos one to get the data on the network:
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
clearScreen();
pinMode(5, OUTPUT); //pin selected to control
pinMode(6, OUTPUT); //pin selected to control
pinMode(7, OUTPUT); //pin selected to control
pinMode(8, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, gateway, subnet);
server.begin();
//enable serial data print
Serial.println("server multi pin button test 1.0"); // so I can keep track of what is loaded
void loop(){
clearScreen();
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("");
client.println("");
client.println("Arduino GET test page");
client.println("");
client.println("");
client.println("
Zoomkat's simple Arduino button
");// For simple testing, pin 5, 6, 7, and 8 are used in buttons
// DIY buttons
client.println("ON");
client.println("OFF");
client.println(" ALL OFF
// mousedown buttons
client.println("<input type=button value=ON onmousedown=location.href='/?on4'>");
client.println("<input type=button value=OFF onmousedown=location.href='/?off5'>");
client.println(" <input type=button value='ALL OFF' onmousedown=location.href='/?off3579'>
// mousedown radio buttons
client.println("<input type=radio onmousedown=location.href='/?on6'>ON</>");
client.println("<input type=radio onmousedown=location.href='/?off7'>OFF</>");
client.println(" <input type=radio onmousedown=location.href='/?off3579'>ALL OFF</>
// custom buttons
client.print("<input type=submit value=ON style=width:100px;height:45px onClick=location.href='/?on8'>");
client.print("<input type=submit value=OFF style=width:100px;height:45px onClick=location.href='/?off9'>");
client.print(" <input type=submit value='ALL OFF' style=width:100px;height:45px onClick=location.href='/?off3579'>");
client.println("");
client.println("");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf('2') >0)//checks for 2
digitalWrite(5, HIGH); // set pin 5 high
Serial.println("Led 5 On");
if(readString.indexOf('3') >0)//checks for 3
digitalWrite(5, LOW); // set pin 5 low
Serial.println("Led 5 Off");
if(readString.indexOf('4') >0)//checks for 4
digitalWrite(6, HIGH); // set pin 6 high
Serial.println("Led 6 On");
if(readString.indexOf('5') >0)//checks for 5
digitalWrite(6, LOW); // set pin 6 low
Serial.println("Led 6 Off");
if(readString.indexOf('6') >0)//checks for 6
digitalWrite(7, HIGH); // set pin 7 high
Serial.println("Led 7 On");
if(readString.indexOf('7') >0)//checks for 7
digitalWrite(7, LOW); // set pin 7 low
Serial.println("Led 7 Off");
if(readString.indexOf('8') >0)//checks for 8
digitalWrite(8, HIGH); // set pin 8 high
Serial.println("Led 8 On");
if(readString.indexOf('9') >0)//checks for 9
digitalWrite(8, LOW); // set pin 8 low
Serial.println("Led 8 Off");
//clearing string for next read
readString="";
void clearScreen(){
Some help would be appreciated. Thanks!
Liviu
