const byte debounceDelay = 5; // delay between digitalReads for switch debouncing
boolean preDebounce = digitalRead(remoteSwitchPin) == LOW; // read remote switch state
if (preDebounce != remoteSwitchWasPressed) // see if remote switch state MIGHT be different from last loop
delay(debounceDelay); // wait to let bouncing settle
boolean postDebounce = digitalRead(remoteSwitchPin) == LOW; // check post-debounce value
if (preDebounce == postDebounce) // see if pre- and post-debounce values agree
remoteSwitchIsPressed = preDebounce; // if switch state has REALLY changed, record the new switch state
I know that blocking code is generally considered to be inferior to non-blocking code, but let's assume for the sake of argument that the blocking is acceptable in this case. Are there other failure modes for this type of debounce that I might be missing? I've done some research on debounce algorithms, and I'm surprised at how complex some of them are. It makes me wonder whether they're addressing failure modes that I'm missing.
Doggone it. I knew somebody would ask for the rest of the code.
// Handle if the remote switch has been pressed or released (updating behaviorState appropriately)
if (remoteSwitchIsPressed != remoteSwitchWasPressed)
doRemoteSwitchChanged();
remoteSwitchWasPressed = remoteSwitchIsPressed; // pass through to next loop()
If you want to try the other route, here's a link to a great tutorial for hardware debouncing. It uses very inexpensive components and is pretty trivial to design and wire together:
DRBArduino:
lar3ry:
I have a wondefully bouncy switch intended for a doorbell. 5 ms is definitely not enough time to debounce it.
With 5 ms, I get between 4 and 7 changes reported. Changing it to 10 ms made it work flawwlessly. I don't see any problems with that code at all.
I tested this switch out with a separate sketch that only read the button, and found that as low as 2 ms would produce no bouncing. If I were to put this code into production, I would probably increase the value to around 20 ms, because there's no guarantee that other switches in the field would perform similarly to mine.
It still isn't clear how "remoteSwitchWasPressed" has a value, the first time that loop() runs.
Ah--I see. I apologize, but the entirety of the code is something like 1100 lines, so I don't want to just dump it all and expect folks to dig through it. remoteSwitchWasPressed is initialized in setup() as follows:
For this application a comparator is better then an amplifier.
The best is to choose an open-collecteur comparator like LM393.
With an open-collecteur you have to put a pull-up of about 1k to 10 k.
I implemented this function more generally, as such:
const byte defaultDebounceDelay = 10; // default switch debounce delay time, if no other specified
boolean isButtonPressedDebounce(byte pinNum, boolean wasPressed)
return isButtonPressedDebounce(pinNum, wasPressed, defaultDebounceDelay);
boolean isButtonPressedDebounce(byte pinNum, boolean wasPressed, byte debounceDelay)
boolean preDebounce = digitalRead(pinNum) == LOW; // read remote switch state
if (preDebounce == wasPressed) // if remote switch state is the same as before, then
return wasPressed; // indicate no change in button state
else // otherwise, remote switch state MIGHT have changed (we'll see...)
boolean postDebounce = digitalRead(pinNum) == LOW; // check post-debounce value
if (preDebounce == postDebounce) // see if pre- and post-debounce values are in agreement
return preDebounce; // if switch state has REALLY changed, return the new switch state
return wasPressed; // otherwise, indicate no change in button state
/ This version of the function performs a debounced read of the pin without needing information about
// the pin's previous state. This means that the debounce delay will always occur. This version could
// be useful for switches where edge detection is not occurring for whatever reason, and so the "previous"
// state of the button is not being tracked.
// The function works by reading the pin's current state and then passing the inverse of that state to
// the "real" debounce function as the pin's "previous" state. This ensures that the debounce function
// always believes that the button's state may have changed, and therefore always performs the debounce.
boolean isButtonPressedDebounce(byte pinNum)
boolean b = digitalRead(pinNum) == LOW;
return isButtonPressedDebounce(pinNum, !b, defaultDebounceDelay);
