Simple DMX Trigger
Hey guys. I'm finally nearing the final stages of making this 4 button DMX trigger of mine. I'm pretty sure the circuit is correct. The dimmer pack says its receiving a signal, but only after a button is held down. And even then, there seems to be a second or two delay for it to get that signal.
I feel like I'm sending the wrong dmx message to the dimmer pack because even though the DMX SIGNAL light blinks when a button is held, none of the dimmers turn on. Anyone have any ideas?
Intended use of controller: https://drive.google.com/file/d/0B_JgvjO0lMw5WXNOOTFYOUVwcUk/view?usp=sharing
Link to schematic: https://drive.google.com/file/d/0B_JgvjO0lMw5RFNBcFdia3VDTnc/view?usp=sharing
DMX Driver datasheet: https://drive.google.com/file/d/0B_JgvjO0lMw5SEM3UnZEOEpmS3c/view?usp=sharing
Arduino Sketch:
[ Libraries used: Bounce2, Four Universes DMX512 Library]
#include <lib_dmx.h>
#include <Bounce2.h>
// User Settings
#define DEBOUNCE 15                 // how many ms to debounce
byte buttons[] = {4, 5, 6, 7};      // Button # and position
#define NUMBUTTONS sizeof(buttons)  // Check size of above array
byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
#define DMX512 (0)
int dmxpin = 10;                    // DMX Driver Control Pin # (MUST BE DIGIAL OUTPUT)
int dmxaddress = 1;                 // DMX starting address
int dmxchannels = 4;                // Number of DMX channels
void check_switches() {
  static byte previousstate[NUMBUTTONS];
  static byte currentstate[NUMBUTTONS];
  static long lasttime;
  byte index;
  if (millis() < lasttime) {                            // we wrapped around, lets just try again
    lasttime = millis();
  if ((lasttime + DEBOUNCE) > millis()) {               // not enough time has passed to debounce
    return;
  lasttime = millis();                                  // ok we have waited DEBOUNCE milliseconds, lets reset the timer
  for (index = 0; index < NUMBUTTONS; index++) {
    currentstate[index] = digitalRead(buttons[index]);  // read the button
    if (currentstate[index] == previousstate[index]) {
      if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {        // just pressed
        justpressed[index] = 1; //just pressed
      else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) { // just released
        justreleased[index] = 1;
      pressed[index] = !currentstate[index];      // remember, digital HIGH means NOT pressed
    previousstate[index] = currentstate[index];   // keep a running tally of the buttons
  byte i;
  //SETUP DMX
  ArduinoDmx0.set_control_pin (dmxpin);
  ArduinoDmx0.set_tx_address (dmxaddress);
  ArduinoDmx0.set_tx_channels (dmxchannels);
  ArduinoDmx0.init_tx (DMX512);
  // Make button # input pins
  for (i = 0; i < NUMBUTTONS; i++)
  { pinMode(buttons[i], INPUT);
  // Run timer2 interrupt every 15 ms
  TCCR2A = 0;
  TCCR2B = 1 << CS22 | 1 << CS21 | 1 << CS20;
  //Timer2 Overflow Interrupt Enable
  TIMSK2 |= 1 << TOIE2;
  SIGNAL(TIMER2_OVF_vect) {
  check_switches();
// BUTTON CHECK
  for (byte i = 0; i < NUMBUTTONS; i++) {
    if (justpressed[i]) { // BUTTON JUST PRESSED --------
      justpressed[i] = 0;
    if (justreleased[i]) { // BUTTON RELEASED --------
      if (i == 0) { //Button 1 released
        ArduinoDmx0.TxBuffer[1] = 0; // DMX off ch 1
      if (i == 1) { //Button 2 released
        ArduinoDmx0.TxBuffer[2] = 0; // DMX off ch 2
      if (i == 2) { //Button 3 released
        ArduinoDmx0.TxBuffer[3] = 0; // DMX off ch 3
      if (i == 3) { //Button 4 released
        ArduinoDmx0.TxBuffer[4] = 0; // DMX off ch 4
      justreleased[i] = 0; // RESET?
    if (pressed[i]) { //BUTTON PRESSED --------
      if (i == 0) { // If Button 1 PRESSED then,
        ArduinoDmx0.TxBuffer[1] = 255; // DMX full power ch 1
      if (i == 1) { // If Button 2 PRESSED then,
        ArduinoDmx0.TxBuffer[2] = 255; // DMX full power ch 2
      if (i == 2) { // If Button 3 PRESSED then,
        ArduinoDmx0.TxBuffer[3] = 255; // DMX full power ch 3
      if (i == 3) { // If Button 4 PRESSED then,
        ArduinoDmx0.TxBuffer[4] = 255; // DMX full power ch 4
      pressed[i] = 0; // RESET?
No links == no help.
Just populating the tx buffer doesn't seem like a reasonable thing to do. I would expect that it would be necessary to call a method to actually send the data in the buffer.
Thanks for the reply. OP has been updated.
Good idea, think I might be calling this too early?ArduinoDmx0.init_tx (DMX512);
No. The mixer example indicates that writing to the tx buffer is all that is needed to send data.
