i've been beating my head against this for a few days now. the actual program i'm trying to write is quite a bit more complex, but the effect is reproducible with this:
Serial.begin(115200l);
if (Serial.available() == 0)
return;
while (Serial.available() > 0)
Serial.print((char)Serial.read());
if i'm not a complete idiot, this should echo back everything sent to it. here's some sample output:
t
tYî
t
e
s
t
tY.÷
this was done through the serial monitor. i sent "t", and it worked. fine. i sent "tes", and the first character worked, the rest got messed up. i sent the word "test" one letter at a time, everything is great. i send the whole word - you see what happens. It's almost as if it's losing a bit or two. very strange.
tried this on two different arduino pro boards, on mac and pc (same computer, dual booted). any suggestions?
Is that a 1 or an L on the end? It isn’t necessary, as the Serial.begin() method’s argument type is an unsigned long. If you do use a suffix, though, use a capital letter, to remove ambiguity (by us, not the compiler).
return;
This is unnecessary. The while loop already deals with the situation where the is no serial data to read.
the second test actually is necessary. the final println() is outside the while loop, as a separator between inputs. if the first if isn’t there, it’ll just continuously print blank lines.
tried 9600, that did seem to resolve it. any idea as to why? in its final use, it will need to run at the 115200.
This speed is a bit high
115200l
hopefully that is just a typo, with extra 1 stuck on the end.
I have cases where too many actions in one line just don't work, this may be one of them.
Try splitting this up:
into
incomingByte = Serial.read();
Serial.print (incoming); // with whatever formatting you want
} // or maybe its due to not having the brackets?
What is the Arduino going to be talking to? Talking to a device that expects a baud rate of 115200 and talking to the serial monitor at that speed are two different things.
