Here's the code.
And the problem is that, the sensors are not detecting the edge and stop.
All I want it to do is move forward, detect an edge, pause, and reverse back and re-detect the edge on the other side. That's all.
It can move forward, but once the sensor passes over the edge, it STILL wants to move forward.
PS. A motor shield is attached to the Arduino. It is the same one as shown on the website http://arduino.cc/en/Main/ArduinoMotorShield
The sensors are the Sharp IR Sensors.
// These constants won't change:
int IRsensorF = 0; // pin that the FRONT sensor is attached to
int IRsensorB = 1; // pin that the REAR sensor is attached to
int propulsion = 9; // pin for motor
int dir = 12; // pin for direction
// Defining front and back
int front = 0;
int back = 1;
// Sensor's definition
//#define BAUDRATE 9600
//#define IRsensorF 0 //analog pin for reading the IR sensor
//#define WAIT 300 //milliseconds to delay
int val = 0; // variable to store the value coming from the sensor
// set the Motor as outputs and the IR as input:
pinMode (propulsion, OUTPUT);
pinMode (IRsensorF, INPUT);
pinMode (IRsensorB, INPUT);
// set direction of Motor as output
pinMode (dir, OUTPUT);
// while the front sensor reading is high, propel:
while (analogRead(IRsensorF) >= 450) {
forward();
// stopping motor when sensor reading is low
analogWrite(propulsion, 0);
// giving delay after detecting edge
delay(10000); // 10 seconds
// while the back sensor reading is high, propel:
while (analogRead(IRsensorB) >= 450) {
backward();
void forward() {
// turn on motor forward
analogWrite(propulsion, 255);
digitalWrite(dir, front);
void backward() {
// turn on motor backward
digitalWrite(dir, back);
